- Jun 22, 2026
I see that now. Also am seeing for the first time that you used the half-breadth drawing as the base for your 3-D box. Ingenious! It's probably too late, but you could if you wanted cut the half-breadth plan in half (top down view and bottom up view) and do a reverse copy of the top down view so you can mate the two halves of the top down view for a complete top down perspective (assuming the hull is symmetrical). I'm very interested in your hooker build, and your building approach, so if you decide to do a build log of the Galway Hooker I'd follow it.Thanks! The two blocks just set the rake of the keel and hold the model so that the frames are vertical. I have to keep going back to the drawings to pull offsets to loft each frame. They just happen to form a neat little box to keep everything square.
