Halve Maen (Half Moon) 1:50 Corel kit [COMPLETED BUILD]
Drawing not accurate
The length of the masts is not indicated in numbers on the drawings. Therefore I measured the lengths from the drawings. There are two drawings, and the length of the masts differences on both drawings for about 10 mm. Not that much, but confusing.
slightly longer masts on second drawing
Bucket out of scale
The bucket under the water pump seems out of scale. Also the material from what it is made from seems Yellowish plastic. I think I need to construct one myself from wood
She looks beautiful, Rene. You have really done an amazing job!
Rigging the masts
Corel provides clear drawings and advices rigging the masts in strict numerical order from mizzenmast to foremast. I completed each mast as much as possible prior to attaching the masts to the ship. In this way finishing the masts is much easier .
I finished all possible component on masts and ship
Furthermore I decided to assemble all the deadeyes first. By doing this in ‘serial production’ I could achieve same dimensions for all.
Now it is time to start rigging the masts from Mizzenmast to Foremast. So in strict numerical order as indicated on the drawings
Dear Ronmedge
you are doing excellent work & Achieves successful and beautiful results.
The Half Moon Corel kit
I do recommend the Corel kit as a first build. It took me 3 months to build. For me it was a second build, but my first build was 30 years ago.
It was fun to build and I am satisfied with the results.
The double plank method is suitable for an first build, the first layer is made of 2 mm planks. You probably need to sand the first layer ( I needed ;) ) The second layer is made from 0,6 mm planks witch are easier to bend.
The 10 drawings are very clear and accurate
These drawings are clearly made from a finished model. Very helpful while planking
The building description is plain text (Italian, English, French and German). You need to concentrate but the references to the text are clear.
An extensive parts list!
