If you have for instance a wood ship from kit, the first thing you do is to
click on this heading, like below "SOS Build Log from Kits - Wood"
THEN, at the top of the page, you will see this: 'Thread title" is a little grayed out, but this is where you type in the TITLE of your Build log.
WHEN you click on the "Thread Title" BOX, then the area will EXPAND to look like this:
The area below the Thread TITLE is where you start to write your text, if you have IMAGES, THEN, you need to click on "attach files" - when you click on that, your computer will automatically open up a FILE BOX where you search and find the FOLDER on your computer that has all the images of your ship. Then you can select one or more.
AFTER you attach your file(s), then you will see the attached file BELOW your area like this:
Look at the bottom of the attachment and you will see "INSERT" - you need to click on that one time and then you will have a choice to INSERT the image and you need to choose "Full Image" on one or all of the images you attached.
THEN will finished you will click on the RED BUTTON "POST THREAD"
When you start to ADD to your Build log --- go back to this thread and just REPLY TO YOURSELF and make another post !!!
Donnie
