HELP! HAHN PLANS_FRAMING UPSIDE DOWN
Are you using Harold Hahn's plans for Bounty? If so, they come with jig pattern as well as extended frames. If not, your best bet is to get a copy. Good luck with your Bounty.
i would suggest you take a look at the Hahn ships here on the forum.
success depends on making sure all the frames are exactly the correct height from the jig base line.
Bob Hunt has a complete practicum on Harold Hahn’s framing method based on the HMS Roebuck. This HMS Roebuck practicum is a scratchbuilt course based on the plans drawn by Harold Hahn (with permission). This course has 12 chapters that cover CAD work, creating the jig, the framing of the model and cutting in the gunports. See lauckstreetshipyard.com “Senior Course, HMS Roebuck”
