If this is the three masted US privateer, former Cormorant you can also have a look at the books of the Swan class ships which are of similar size as this Rattlesnake.
If it is the two masted brig Ratlesnake which is similar size as Alert you could use the data from the Alert book.
Very confusing subject ROTF Not only 2 but not less than 10 ships in the Royal Navy has been named HMS Rattlesnake according to Wikipedia:
Allegedly at least 2 of these (1783 & 1814) were both previously American and both captured by the Royal Navy.
According to Wikipedia both of them were brigs. AFAIK a brig has 2 mast so I guess at least for the HMS 1783/USS 1781 this must be wrong.
I think the one that Hahn build was the HMS 1783 / USS 1781 one.
Was the HMS 1783 / USS 1781 ever sold back to America? I could not find any evidence of that, but several sites seem to believe she ended up in France
It also seems that a lot of modelers and other people are mixing these 2 ships up. Just one example:
Sorry for the hijacking Maarten, just to show that the year along with the name is far from unimportant :-)
Back to Alert, which also had a sister called Rattlesnake :-) , to make it more complex.
Stil working on the ceiling, laying planks in the second part.
second part finished, time for making treenails.
Treenails before sanding.
And after sanding.
Compared to actual birchwood treenails on my Royal Caroline which is I think 50 x the work.
And finished, one more to go.
@Maarten, the question is now solved, it is the three-masted American privateer, the former cormorant, I did not now that she had the name cormorant before, now I will see if I can find a suitable book about the Swan class, Uwe can probably help, thanks all the help, sorry for the burglary in your log.
After filling in the first two areas between the thickstuff with ceiling planks it is now time for something else before finalizing the last ceiling.
I will fit the first knee in the stern and bow as well as the mast step.
These knees are pre milled but need a lot of work to fit properly, especially on one side where I added the ceiling planks.
After filing, fitting, filing, fitting etc it finally fits and is glued in place, bolted with 0,6 mm steel wire and left to dry.
After drying the bolthead are cut and rounded with the cup burr.
Next is the mast step, build from 3 parts. The top 2 are already modified for fitting my ceiling.
After glueing, finishing and bolting fitting into the hull.
Now I will temporary fit the lower deck beams, just trim and make these properly fit before finishing the ceiling.
If other Alert builders think what is he doing, the manual is showing other things, yes you are right. I don t follow the manual as I plan to do something different so I determined my own building sequence which will be different then the manual shows.
I removed the hull from the berth again and glue in the distance pieces for the template to mark the cutting spots for the frames.
The template is fitted and at the marked positions I mark the frame with a knive.
In the bow I drill the hawser hole position.
After removing the template all the cutting spots are clearly marked.
Now I will set out the main wale.
The cutting markers are the timber tops which I use as reference to determine the wale position.
I recalculate the dimensions as the model is 1,031 x the drawing dimension.
This I do at multiple frames and mark the wale lower edge into the frames.
The wale is made of 4 scarphed planks and for these I make the scarph joints fit properly.
Then sanding followed by steaming them into the proper shape by steam and drying and bending on a heat plate.
A proper bend plank fit into place without applying to much pressure.
To glue the wale in place I made some DYI clamps from m2 bolts and brass plate.
A single clamp at the bow.
The first wale section glued and clamped, the second ready for fitting.
All fitted with clamps in place to dry the pva glue in 24hrs.
The clamps on the inside around the clamp shelf.
Now ready for receiving the bolts after the glue has dried.
Cool clamps! I learn something with every posting!
Dear Maarten
it's looks magnificent :)OkayThumbs-Up
Thanks for the detailed explanations and photos
'Black' background. you are learning fast, Mon Amie!!! What was the reason drifted from the manual course? Will you paint 'black' the wales?
The black background is due to the flash, I just took it in the livingroom with dimmed light.
Why deviating from the manual. First of all I am not such a manual guy, just build and see. But as I will add the outer skin on one half I want to have it on before starting on the inside, otherwise you will get a hudge amount of dust and particles in the interior which will be difficult to remove afterwards. So first I do all the major construction works and sanding. Secondly I still need the space on the inside and also sufficient rigidity of the hull without deckbeams fitted, but I will explain that later.
The wales, one side of the ship will show the plain wood construction, frames, deckbeams, bulkheads, this side will be unpainted or coloured. The other halfside will be fully build, coloured and decorated.
The current wale will be plain, the other one black.
Some painted friezes, perhaps?:cool: You are doing such a fine job with this cutter. Beautiful!
Very good work - and thanks for sharing the idea with these brass clamps ! Very good idea for planks like the wales where you have both sides available and on the other side another clamp-plank has to be inside the frames on the same levels - I have to keep this idea in mind for future problems :cool:
Thx gents for your comments. Thx to SOS we all pick up new ideas and techniques.
Today only some minor progress but still a few hours of work.
The clamps are removed from the wale, holes drilled and 0,6 mm wire fitted as bolts. Again the wires were finished with a cup burr which finalizes the SB wale. According the drawings and other data I could find the bolts are more or less fitted at every second frame. I have to figure out if the in between frames were maybe tree nailed as is done with the hull planking, maybe someone has more data on this? You can also see the markings for the frame cutting clearly.
Before continuing on the PS wale I will first work on the stern. After marking the stern cutting spots I have removed the guidence pieces for building up the stern transome so now the stern is also completely free from MDF templates showing it beautifull lines fully.
I am working on the tafrail which consist of two parts which first need bending into shape followed by glueing together. To get the correct curvature I use the provided template which I first bend into the stern curvature.
I also use the template as a clamp to glue the two layers of the tafrail together.
Now that has to dry for 24 hrs so that is it for today.
The freeze is dry in the meantime so lets continue. As I glued the two curved pieces together you get a nice solid curved part.
According the drawings the freeze should get a curved edge which I create with a round jewelers file. The the outer edges should be filed in the correct angles to get a proper fit in the transome.
During dry fitting the part you see it neatly fits into the template.
Finally fitting the parts. Pictures from multiple angels show you the shape of this part.
Next is work on the fashion pieces BL 42, these get an additional half frame which has to be sanded into shape at multiple angles.
I first sand the angles fitting to the stern and the upper transome. Then it can be dry fitted to mark the lower and upper dimension.
Now I sand it in the correct angle towards the marked dimension on the discsander.
Now glue it in place, the rest of the trimming I do when the part is fixed.
Now the lower transome parts BL29, these also have multiple angled surfaces but a sticker template is provided to give the the right shape.
The right shape, still a lot of trimming is needed.
But they fit allthough the SB one needs some fine tuning. I clamped them with some wood strips during drying. An additional transome part will be fitted after the glue dried, then final trimming is done.
On the inside I now have a nice edge to fit the ceiling planks onto, this is one of the reasons why my build is totally not following the manual anymore.
At last I also prepared the PS wale after scarph trimming, steaming, bending and colouring it with black Ecoline ink it is time to fit it.
Now it is time to dry the glue before we can continue.
Enjoy your builds.
Work on the lower transom continues.
The last part to be added is BL 43 which is glued on top of BL42.
This part has a lot of additional meat which needs to be trimmed. Again first the part joining to the stern should be trimmed so the part is properly fitting in place on top of BL 42. Then the rest of the parts should be trimmed to follow the outlines of the lower transom, to these the stern planking will be fitted.
Below you see the part trimmed and untrimmed and you directly see how much material is removed. I did this by using my disc sander.
The final trimming I do when the part is glued in place so you have optimum control over the shape of the stern. So now I glued the part in place.
Followed by preparing and glueing the SB piece.
While these two parts dry further work on the wale is done.
The clamps are removed.
And the wale is filed towards a flat and smooth surface removing the imperfections from the fitting process. Now holes for the bolts are drilled and again 0,6 mm anealed steel wire fitted and cut. The finish of the bolts again with a cup burr.
When all bolts are finished I will once sand the wale with steel wool followed by a final layer of black Ecoline ink. This is later finished and sealed with oil.
