HMS Druid P.O.F. - Unicorn Models by Donnie
Donnie
Administrator
Administrator
Madison, MS
This is the beginning of my Build Log of the UNICORN Models HMS Druid P.O.F. Kit. The images are from first box opening and laying out as much parts as I could. I did not layout every single bundled piece, but if anyone has any questions, they are welcome to ask.
ZHL now sells this Druid kit with the upper deck framing added as a bonus now. The instructions to the bonus package is all in Chinese, but not a problem as I downloaded an APP on my iPhone (thanks to Zoltan) as it is an Optical Character Recognition program. You can operate the APP two ways. You can SCAN the document and it will translate for you, OR, what is really nice about the APP, is that you can also view the documents translation in real time (as you hold your phone over the document, it will translate as you are looking at the phone. This is pretty cool. However, Chinese to English translation can still be somewhat awkward as it seems that there are only a handful of Chinese characters that can correctly translate to English as the English language is complicated with one word having multiple meanings.
Ok, so the MAIN instructions are in English with pictures. I have not taken the time to review the manual completely. As I start this build, then all those details will come out. In the meantime, sit back and enjoy watching if you so feel inclined to do so.
The box contents are bubble wraped and then the entire contents of that is also in a clear plastic shrink wrap. I think this kit would survive the harshed environments. I have never seen a kit that the entire inside was completely shrink wraped sealed up.
Donald
Donnie
Administrator
Administrator
Madison, MS
Stargazer,
this is the Cherry version. The Length is 655mm or 25-13/16 inches from tip of stem to the tip of stern. I assume by your username, you do Astronomy as well?
Thank you everyone for watching. I am now building the jig and filing off the char. I found that just by filing off the char, (and no more), the pieces fit exactly as they should.
Donnie
Administrator
Administrator
Madison, MS
Ok, so first things first. The instructions call for making all the frames first, but for some reason, I guess I need some warm-up time and I decided to build the Jig first.
I used a basic Shelf that can be found in any DIY store.
The two large bases have a laser-etched pattern on them that shows all the frame locations along with the frame numbers. You will not see that in this photo. The bottom part of the Jig is being built first and is actually "upside down" which is the reason why the laser patterns are not seen. This is the bottom part of the Jig.
The RED arrows are showing the location of small brass wood screws I am using as the two halves of the Jig do have a very slight bow in them. The slight bow is nothing really to be concerned with as when the bottom part of the box Jig is built, it will square up. I just wanted to take extra steps as with the bottom part of the two halves are screwed down, the pieces can not move around while I am gluing and fixing the other parts.
There are also numerous "right triangle" pieces that will also glue to this bottom to keep it square - however, it is always best to use a real square when checking. After all this "is" the Jig - right?
I found that just removing the Laser Char, and no more, the parts fit nicely. There are a few areas that might need just a very small amount of filing, but not much.
Stargazer,
Hey Donnie, I used to be into astronomy- I had a Starmaster 20” Dobsonian and several very nice eyepieces, but after 4 back surgeries and just age in general I just couldn’t haul that behemoth around and do the all nighter’s anymore - I have considered a small apo refractor but I just put the $$$ into ship modeling and keep building....
Donnie
Administrator
Administrator
Madison, MS
Actually, I do not really have to have the google translation app bc the English instructions are compiled at the very beginning of manual w reference numbers to images. Just a little getting used to this format. I have more pics coming up soon.
Dave Stevens (Lumberyard)
Sponsor: dlumberyard
Sponsor
i think for the money it is a very high quality kit from what i see it is based on the Hahn model and a great interpretation of the subject.
Even though all the frame parts are pre cut it is the next level of model building and will require skill to build, kind of preps you for scratch building should you want to go to the next step in the hobby.
Donnie
Administrator
Administrator
Madison, MS
I am still working on the bottom base. To me, it is very important to have a very straight - flat surface as this base has the 'frames' layout laser etched on it and also more important, this is where the keel will be laid along with the rest of the structure is going to be supported by this base.
The two aluminum bars are an example of how I was able to put weights to distribute the pressure. Even though the jig top part is screwed down on the shelf, the two halves still have some slight bow and you can still press the board in the middle and it gives up and down just a little bit. The point is that the rest of the support beams has to be flat as they are being glued down. This might seem overkill, but if you were to build this bottom base, you will see that it is necessary to have the steel weights and those red anvils press down while the beam dries.
As a side note - that center joint is NOT glued. (I figure that the glue from this would make removing the bottom base very difficult to do if glue leaked onto the white shelf.
Donnie
Administrator
Administrator
Madison, MS
Thank you Dave for mentioning this.
This is a very important note. Even have done a scratch-built cross-section myself, I can say that this is still an advanced kit, and making frames (even from a kit) can still be a confusing and daunting task.
Donnie
Administrator
Administrator
Madison, MS
Well, I know this is the mundane part of the build, but again if you are reading this and are starting this model, then it is very important to get this part done right. If not, then the rest of the build will be compromised. I know that a Jig is not a glamorous thing. But it is what it is. This determines how the ship will square up and reduce a lot of problems before they arise.
Here, the bottom part of the Jig is complete and drying. It will be removed from the white shelf soon.
Next, is a more fanciful part, and that is the top part of the Jig that shows the frames (locations). It will have a shallow box built around it as well. Again, the two halves are very slightly bowed and need reinforcement. The same technique will be used for this top as done for the lower. The slight bow is not a problem. That is the reason for the reinforcements. I am not concerned about it - it is to be expected. It is really up to you/ me to make it right !!!
