HMS Guadeloupe (ex french Le Nisus), Brick de 24 by Jack.Aubrey - 1:48 scale
Friday, August 26th, 2022
The fact I was successful to precisely glue the lifeboat frames, all of them well aligned and spaced apart, has enormously simplified the assembly of the next element that you can see in the two following images.
The installation of this new element has also strengthened the overall skeleton of the lifeboat which, you have to believe me, is really a very delicate object to handle.
01 Brick de 24/26082022/IMG20220826185138.jpg
y4moHtrkRMjHHAIxB-DhxobUZ2OqrxKXMZcBb4o8dIAf1IQi8A138uaY-b4hK-Q94r4TN2iRBNVU1okgTj7qtliyt02piYiclU3XwiThIPeA5-8ByCaxgSD3nJ_Apd8fxgC27SgHUHA7CU7oYUDnObK412DrjTIPQho9mf4kedMtsRmr0QGJHzclFLPdaIqtzdH
02 Brick de 24/26082022/IMG20220826185151.jpg
y4mItM9_5RXBAknmnLIodN30IiE6AMPQWfev8FosXD_RAx3l8fXjc8lNEz3QyFrVR6KazzZUJxnkDhPle1GHKBu7dHWON3Mil-jpq-dAc-n_S717sJh6j4hyamHrQkhDZABJOkkCDtPBBx59sN18pkGkl9onAOw0NvVqMKz9FXdEw480fih0XBGuurJLFbHEbra
See you soon,
Jack Aubrey
Sunday, August 28th, 2022
One of the preliminary operations to apply copper to the hull of the brick is to build a tool to trace the waterline, tool I built today. It is a quite simple and handcrafted object but it has all the necessary customization possibilities.
01 Brick de 24/28082022/IMG20220828174152.jpg
y4mRIkXEQmxxg30OqseUhYZ6g9dVEXqDfYfXxGptph3WPuyNzrPW1U5JCNhKQpPCndlp4c7w73uQCL1Hq0LDqxO3TL0MAtRsDcM26R0Up5FpvghFA7Oycut-Fv4R-Hlm6gL-OJbhz0xUTdRwvsrx9U2WKNziSLx16l2lRni2PYqk4bi4rttQTTjo1dRxlqOFAw4
02 Brick de 24/28082022/IMG20220828174159.jpg
y4mgc0_ASLT4GgRvpSHMU2qYHrBzH2lpW-dAWS9iGidT85_gKKmVVhH4O3FSAwmL_m6nWe_rqPO0uVFFFCee4ccElGAqC3RyBfsSsoFeBQwkb30NnHYJvmGBZm0ioR879AA-IeFSinR35yVr4Ld7lpnlfbWskSHkagVq_YDrR4Ps8f8FCpmoYKHW7wZLk2qEtSO
Finally, I applied new elements to the lifeboat: in particular, these are pear elements that embellish the seats for the crew as well as reinforce them further.
03 Brick de 24/28082022/IMG20220828174313.jpg
y4mVbtz9er6RHOtAaReSkKqJJIgcBsqRqvVjbOFu2FyvWrFG-x2j4wqYc4GJQ2YUrbbDttTOTQ6d_jG563Yy2Dyce9XeUyN6eyEwz2hQBiaW5mAJjRsgjYpfEHaEdF-4l9AC19cURn9TqUT6GPErbQ0asvRrd0Iy-HjBH1JTWcxiDS5EDTl2_s78YScb1jVW8lp
See you on the next time; a cordial goodbye from
Jack Aubrey
Monday, August 29th, 2022
Another element added to the lifeboat: these are two pearwood pieces that make up the gunwale. Its installation was not very easy but with a good amount of patience it succeeded very well. The boat structure should now be complete so that next step will be the installation of the planks.
01 Brick de 24/29082022/IMG20220829164723.jpg
y4mhK2B_nAfLoA0MdjiDOgwRPuQ52x8caygKa2Bqk1t2mdKY02BaqJPECmQoQyObmYwogTwP-swVWMdswJtmlBFQBr8-DfED0tV-CwcHv7CeWOx60TxuO_gr1fAgLG1Q9-iUWhNydmkWwWyHUA-2X8EJDmQG0zT_53Pc_2eA19MZjrszR4QDXsyL3rmhokKVZrl
02 Brick de 24/29082022/IMG20220829164755.jpg
y4miO7eAUOXANJDQ0r_-ihCBvrJepG8g6uka743LiuxGcBN2S6XCBU81VZFSc9-lUrS4YEULZWSztHj5s51VmBfasxrvyEXMvk2YiOKkZ_3py_qfv3Zh_9tHdpGW6xrnrcUkS7Y6vea_Wvx84S5BL4PCwPFxqTwpas87WLxseJhwLRyDdK7NUgd3vcMa-R7-2Yb
03 Brick de 24/29082022/IMG20220829164806.jpg
y4mLU8AL_ho5ow2DaGqqfF5zDmI1J-4PFMQmN0NwevcUJjtcsJr3_bhL21wur_TOaXkwLQX2olidgLyGRmVFINEnV3eBwDfDHN4MlXflO2ud7FD_1mDHiDyetQ3p_wnL7HOK47MjT2oCY0KPs4e0KY7mj1WXBetBZJigOlU7w7MagCbljX_Li525HLWLXtnhvWL
See you next time,
Jack Aubrey
Friday, September 9th, 2022
I've been trying my hand with planking for a couple of days.
The various courses of the planking are also laser pre-cut and therefore are quite precise in following the lines of the hull. However their installation is not a very simple task.
First of all, it is necessary to hot-bend the strip in the bow area giving it the right curvature, then it is necessary to proceed very calmly and patiently so I am limited to installing a maximum of a couple of courses per session.
However, until now, everything seems to be going well.
There remains the concern for when I will have to install the last course: will it be accurate? will it be abundant? or will it leave an empty slot? We will see . . .
01 Brick de 24/09092022/IMG20220908184332.jpg
y4mnOukidHCBGIgKSYwPjtaGYyJZaaGGq5arFDpy4CukXWnt8DwmYYNna11mLuJMYobUloEJGIjsEVvs6reVCjY5AAiZh8boas5QBYZ4ACMZ15PfNFG4hZCAFmLwIfCLOUa5rM5UuB4_Yzhzt4lXe5aoIMBvWgcFnhm_YBh0nXmvSTRHqqtvsrBGAUJE38tQET-
02 Brick de 24/09092022/IMG20220908184339.jpg
y4mellpDeOHWWnUTA1N3t5dS8G1LjtlRqCUGaOdU5yf3WeIPgac8rorp1GYC8BY-y4WRzUhD97Tddp-MHwr5XGd77ZsjYiVbwkaFltxZ6mSiKo47_euYiPoFzAZ3_stOr_A1XjebQx9XxaNVHXQBAEhl1XNJ5wQitvFtIbRa2BmEsauuZYvwmrJweSaX59LPU_a
03 Brick de 24/09092022/IMG20220908184359.jpg
y4mQLRHlJBHcZJgZNQlGG97h9zVIj6Vmvb75MJgvgsdawmBd6cDEQEpOULtgOZiSzte_0lQcvEVAGXLZ2nTE6c8QnPO4QDFvf2XOkA0YpNAmv_Cf0_uEgHPhs0VdgQiomc6mIl_-_fhYf4w5pY8OFyzFKFzX9qjsYZBkxvCns27rwX_NnV6iUKKwKyyC4sqiXsN
See you next time,
Jack Aubrey
