HMS Kingfisher/ King's Fisher - Tedboat
Uwek
Admin
Administrative
Blandford Group Build
Vienna, Austria
Ted,
unfortunately it is only possible to give "one" like - but your post about treenailing deserves much more !
Many thanks for the detailed personal experience, which I can fully underline.
It is very good and detailed tutorial and should be saved in an general area.
Therefore I kindly ask you to copy your post in this area within a new topic:
tedboat
Well-Known Member
UK
Ted,
Hi Uwe,
Very good of you to say so - I actually wrote the piece some years ago, but still relevant.
Will see if I can put it on the general area.
Ted
tedboat
Well-Known Member
UK
Carrying on - a few more photos of the build:-
Pretty much the same as last photo, but with the ledges going in, spanning between the carlings, which in turn span on to the deck beams.
Ready for planking.
The start of planking the gun deck. The outer planks are laid 'top and butt style - supposed to give extra strength.
The planking also tapers to bow and stern.
Hooding of the planking at the bow, to avoid planking thinning to nothing.
Planking along side of ship, showing scarf joint, gunport and sweep port framing, pulley block and trennels.
Abit out of sequence, but illustrating how I bend timbers.
Method:-
1. Wait until wife has gone out.
2. 'Borrow' saucepan.
3. Boil timber until pliable.
4. Use folding wedges to secure timber on mould and then use electrical tape to pull in to shape.
5. Forget to remove evidence before wife returns home.
6. Apply lotion to bruises.
7. Leave timber to dry for 24 hours
Starboard side deck fully planked. Port side to be left in frame.
Sweep of deck planking from stern - Very happy with it, but will do better on the next ship.
Ted
Uwek
Admin
Administrative
Vienna, Austria
Very accurate work - great work of a very good kit.
Did I see it correctly: are every beam and carling made out of 3 parts, so the notches for the carlings and the ledges are not cut out, but prepared by the laser of the outside two parts?
I have the same system with my La Salamandre .....
tedboat
Well-Known Member
UK
Absolutely right Uwe. All the deck beams and carlings are composed of three laminations. The only difference is that all the parts are milled out, rather than lasered
Ted
tedboat
Well-Known Member
UK
Ted - I am curious... do you have any idea of the total number of hours you put into this build??
Mike,
Very difficult to say - I started building in early 2012, and in an average week probably spend six to eight hours working on her, which equates to something like 2300 to 3100 hours so far.
The bottom line is that it takes time to do full justice to this kit, so if any of you SABLEs out there have one stashed away, you had better get going!!
(SABLE:- Stash Accumulation Beyond Life Expectancy)
Ted
tedboat
Well-Known Member
UK
Right - Time for a few more photos!
In contrast to the main framing, the stern framing of these ships was very much lighter and weaker, and depended on a couple of transverse transoms and four dog-legged frames.
The positioning of these frames are difficult, due to the curved shape of the stern, so a temporary jig was devised. The lower cross-timber is not the lower transom (or counter), but marks the point where the frames change direction.
Stern timbers from inside ship. the start of fitting out with window cills and the lockers for the captains possessions. The vertical timber in the centre is the extension to the sternpost. The sternpost on the Swan class sloops generally ended at the level of the lockers, but I elected to add the extension to give support to the rudder trunking.
The rudder - part complete
Building the stern windows. Joints halved. Each window has to be shaped to fit the stern framing, and they are all different and fiddly.
Windows going in. The windows are glazed with microscope slide cover glass - very thin and tricky to cut, but gives a very good result.
Needed a break after the complexities of the stern, so worked on the cannon. By now, you will have probably realised I am a great believer in the use of jigs to ensure all is as it should be. I made a jig to hold the gun carriage side upside down and with the correct taper while I attached the axles. It worked very well.
The ship only mounts seven guns on each side, but I made an eighth to be on the safe side. When I finally mounted the cannon (about three years later) I used the spare as part of the display on the base.
A forest of cannon after spraying. There are far more cannon in the picture than I needed, but I made up a set for a friend down south, and more for a cross-section if I ever get around to it.
That's about it foir today - hope it was of interest.
Ted
tedboat
Well-Known Member
UK
Mike, Dave, Uwe, Jim, and others
Thanks for your replies - maybe we should form a jig party at the next election - would probably be of more interest than what we're going to get!
Ted
Jimsky
Moderator
Brooklyn, New York USA
I am not sure if I am the correct Jim, (lately, we get more Jim's, the more the better! YAY :p ) But I like the idea of Jig's party. We should get a mini competition on our forum for the best, useful jig. We will encourage mates to submit their jigs and whoever's gets most votes (likes, loves) will be the winner and like the price, gets logo or tag: Master of Jig!!
