I would like to start a build, so many questions. Need everyone’s experienced advice and direction. This is the scratch build wood kit of the HMS Victory’s launch by Mantua. It has a double planked hull. I have started the build as you can see, the false bulkheads are in, squared up, level and perpendicular to keel, as best as I could get.
Top 3 planks and the Garboard plank are in place. The first layer of planking is 6mm wide while the outer layer of planking is 7 mm wide.
I want to use this build to move my model boat building skills to a more accomplished level like the fine and detailed ships I see on SOS Brian B
