Huvema HU 22BS scroll saw machine 1998 (SOLD)
<<SOLD>>
I am not using it so may it go away, no need.
I have checked the machine completely, cleaned and lubricated where needed.
Despite its age (25 years) it looks fine. In fact it even performs fine. Huvema scroll saws are durable.
This machine is larger than the average machines and made entirely of cast iron, steel worktop, bellows is fairly new, 24 new pin saws and also about 20 ordinary saws that you can clamp with an attachment. Dust collector that you hang underneath by magnets. Mounted on a thick board with rubber soles. Note machine weighs 31 kilogram, so only collect in the Netherlands nearby Roermond, Belgium nearby Maaseik and Germany nearby Aachen.
Maximum saw thickness is 50 mm.
discharge (cutting depth) 550 mm.
saw blade length 125 mm.
Rev/min. 1420
220 Volt, 1.1 A. 242 W.
weight 31 kg.
Maximum cutting thickness various materials:
Wood: 50 mm.
Hard plastic, pexiglass, hard and soft rubbers: 40 mm.
Copper, brass, hard aluminum, silver, etc.: 10 mm.
Medium-hard steel: 5 mm.
Send me a P.M. if you are interested
