• At some point from current UTC of 19:40:30 Thursday up to UTC 19:40:30 Friday, it is possible the forum might be disabled for a short period of time for updates and upgrades. Another notice will be posted for status. Note: Central Standard US time would be 14:40:30 Wednesday up to 14:40:30 Thursday
I saw that
I use these bore 10mm and 85 mm total. They work fine! And for the price of 1 proxxon you got the whole set of Newone. There are youtube movies where you can see a test
explanation of a saw blade for Proxxon
Here you see you Proxxon saw blade.
85x0,5x10 mm 80Z is the type on the saw.
this means:
85 is your outside diameter.
0,5 is the thickness of the blade (cut it makes in the wood)
10 is the diameter of the axle where the blade is attached in your saw.
everything in mm. millimetre.
and 80Z is the amount of tooth on the blade.
For an Proxxon FET you need a saw blade with a bore of 10 (the inside diameter of the hole)
And an outside diameter of 50 mm. to 88 mm.
This link https://nl.aliexpress.com/item/4000071259411.html?spm=2114.13010708.0.0.3a994c4dvs2y98
is where I ordered my saw blades too.
I ordered those 5 saw blades.
