One of the most impressive things about SOS is the massive amount of information it contains. Many of its members have done an impressive amount of research and have an impressive amount of knowledge about how to build models, and I often use it to find out what they know. The difficulty is that it's often difficult to dig this information out. This difficulty is not unique to SOS, but to all other ship modelling forums as well.
One of the biggest problems I have is that when I search for something, I often get a large number of "hits", many of which are of limited relevance. I am wondering, therefore, if it would be possible (and not cost prohibitive) to add a feature that makes it possible to use Boolean operators. The ability to use these operators is typically found in large databases, and using these databases would be nearly impossible without these operators. Let me give a trivial example of what I mean.
Let's say I'm interested in how to make a build board. Clearly, if I search on "build" or "board" I will get a massive number of irrelevant results. I can narrow them down a lot by using Boolean operators, which are AND, OR, and NOT. For example, with these operators, I can search using the terms (build AND board). This brings up all entries that use the phrase "build board." It won't bring up all relevant entries, though, because some folks call it a building board, and others call it a construction board. So, to account for this, I can search on (build OR building OR construction) AND (board). This will give me a pretty clean and comprehensive set of results.
You can use these operators for all kinds of searches, ranging from the deck planking on the HMS Victory to whether I should use CA glue to keep the ends of my rigging lines from fraying.
I don't know whether it would cost too much to add this functionality, but it would be very helpful, so I thought I'd ask. Thank you in advance for your replies.
