Kolderstok Willem Barentsz, AD 1596
Maine, USA
Okie Dokie, back to square one. I added the next set of 1.5 X 6mm planks working my way up the hull. But the more I looked at the Port or Starboard side the fit just was not right. :(
Back to where I started at the beginning of the week, these planks will also come off, mainly because of the humidity problems noted earlier. A close look at the lay of the initial plank (1.5 X 4.0 mm) on the Port side, shows that there are four frames that the glue bond has separated between the frame and the Bulkhead. In order to get a good foundation for the planks my best bet is a major do over. ( Ron can overnight the coins)
Would it be too late to consider using fillers, like @Heinrich did on his WBII build, to increase your bond area?
Maine, USA
I thought about that but the "wiggle" in one laid plank carries into the next. I have one bulkhead that needs a .65mm or so addition to bring it in line with the other bulkheads. My problem is/was the first foundation plank. ie. the first to be laid "even" with the deck to match the lines scribed in the bulkheads. That plank becomes the foundation or starting point for the rest of the planking.
(Picture by Heinrich)
The arrow points to what I call the foundation plank and it is the basis for the rest of the planking.
I followed Heinrich's notes and got as far as placing the three planks and Wales on both sides. The hull then sat on a bookcase while I was working on another ship. I started the build again at the beginning of the week and noticed gaps where the "foundation" plank had separated from four bulkheads. The second worry was that at the stern three planks bowed out.
When I added the next set of planks the distortion became worse. I spent a bit of time shimming, wiggling and diddling trying to make a fix.
I don't know if the above makes any sense, but it's easier to start over.
Heinrich
Bluenose Moderator
From the picture it is impossible to tell that there any issues with the planking, but you will know best. A man has to do what a man has to do. Do you edge-glue the planks as well, Jan?
So in short, it's the first "foundation" plank giving you the issues, after sett mg the WB aside for some time? Did both "foundation" planks become detached or is it one side only?
Did you, by any chance, check the straightness of your keel in all three directions?
Heinrich
Bluenose Moderator
@RDN1954 Johan, I can categorically say that the keel will be as straight as the proverbial arrow. I don't know which glue Jan uses - if it is Titebond, I am not surprised. I have recommended Bison D2 to Jan - the wood that is used in the Kolderstok kits love that glue (don't laugh:)). Unfortunately, I cannot get Bison in China, but I have struck it very lucky with the Chinese PVA I use. It is simply brilliant!
@Heinrich, I was not implying that the keel, as supplied bij Kolderstok, isn't straight, but as soon as you start using adhesive, it is not unthinkable that parts see warping. I've observed the same phenomenon on my BN build, where the initial keel assembly was shown to be as straight as an arrow, but after three months no more. Not caused by faulty (warped) parts, nor by the builder, just the environment, claiming it's dues.
Heinrich
Bluenose Moderator
Okiedokie - now I am with you Johan! Thumbsup
Heinrich
Bluenose Moderator
I am deeply worried about the debonding. What will happen in a year?
Me too, Paul. I simply do not understand that. I planked my hull in the middle of winter with temperatures of zero degrees, Now, we are in the middle of summer with temps of 38 degrees Celsius and 98% humidity some days - no issues.
Heinrich
Bluenose Moderator
Jan I now went back and re-read your whole log. I see you do use the D3 Kolderstok glue that Hans supplies - which is basically Bison D3. The only difference between D3 and D2 is that D3 is waterproof and D2 is not. Thus, there is no issue with the glue. used Now, I am even more confused as to what caused the debonding! :( :(
Maybe, apply more glue and clamp more aggressively and for longer periods. The sway of this hull puts a lot of stress on the hull planks.
Cape Town South Africa
Good morning Jan- Eish. Redo’s. Part of the hobby for sure- I think Ron better open a mint for the SOS guys. ROTF . Cheers Grant
Maine, USA
Yes I edge glued and glued to the bulkheads. The entire plank assembly is/was
Both sides were affected. On the Port side bulkhead #3,4,8 and 9. On the Starboard side bulkheads #3,5,6 and 10. The straightness of the keel is OK. I used a caliper to check the spacing between all bulkheads at the keel and also at the deck level on both the Port and Starboard sides. No problems there,
My thoughts lead to coefficient of expansion. I’ve been storing my partial completed hulls on the top shelf of a bookcase. Unfortunately I never gave any thought to the full sun from the adjacent window most of the day and our high humidity this time of year.
Heinrich
Bluenose Moderator
Yes Jan - the direct sunlight, I think more than the humidity, or then in combination with the humidity, were probably the culprits. You are right - if the adhesion is compromised on so many bulkheads, then best is just to redo everything.
Wadsworth, Illinois, USA
It's all part of Heinrich's plot to get everyone who builds this ship to build it twice.
My bet is on the combination of heat ánd humidity. Especially if you bonded the planks with tension against the grain to follow the decks curvature, which would result in peel stresses on the bond in itself. Add the heat and humidity to the mix and you have yourself a nice recipe for "disaster".
Maine, USA
Hi Heinrich, You are correct on the keel. I use Gorilla brand PVA which dries clear. Bison is hard to find here. The only Bison D2 sources (other than their CA) I’ve found are in Europe. I’ve had no luck trying to order from England or Poland.
Maine, USA
I‘m thinking that fully planked and sealed there would not be much of a distortion problem. The hull in this case had the minimum amount of planks glued up. Three to a side, so there was a lot of wiggle room at the top and bottom.
