La Volage. ANCRE. 1:36.
Good work on the gun muzzles - but I can see only nine molded muzzles - The Nereide had 10 guns........
The carriages are looking very good
I am looking forward to see, if you install the guns in "stowed" possition, or "ready for action"?
I am not a specialist for the tackling of these guns, so therefore I could be completely wrong.
Your breeching rope(s) (#1 in the sketch) are looking very short, so installed guns can not be loaded, because the front end / mouth of the muzzle will be still outside of the gunport, so did the gunners remove the breeching cable from the wall before they moved the gun backwards to load the gun ?
Палуба узкая, поэтому брюк короткий. А заряжать придется через борт, как корранады. Пушка маленькая, 4-х f. Я для масштаба поставил солдатика в 35 масштабе.
The deck is narrow, so the trousers are short. And you will have to charge through the side, like corranades. The gun is small, 4 f. For scale, I put the soldier in 35 scale.
Начал делать шлюпку. Сделал болванку с пазом для кильсона. К кильсона приклеил флоры. Потом к флорам киль и штевень. К ним же верхние части шпангоутов
Then I made a hat. Made a bowl with a saucer for Kilian. Flowers were attached to Kyleson. Because of the flowers, Kiln and Shrew. To them are the most important parts of the spangout
