Le Rochefort 1/36 - Build Log by Moreplovac
Ok, some surgical time was put in LR and results are, ah, well, so-so but at this moment not able to do better without scraping it in wood-burning pizza oven, which I don't want to do.
I was able to glue back broken pieces and now, need some sanding and special techniques to hide those spots where extra glue and cracks are visible at this moment.
Also, I finished adding filler pieces at the bow, feeling like a dentist when you go for a crown work: put crown on, bite, not good? Sand, bite, not good? Sand... since I was able too use plan template for filling pieces only up to certain point; after that was all test fitting/sanding... but I got it decently installed.
Aslo, working on installing stern parts which will have a hull ready for more sanding.
I am running out of wood so need to place an order for more woods which will put LR on short hold until wood arrives.
In the meantime if you have nothing to do, you can follow my new build of ZHL MISTICQUE..
Happy modelling..
Great achivement so far. Try a small amount af PVA glue applied to the cracks just before you start fairing ribs by sandpaper.
Little bit of sanding was done on my model…
Need more clean up (scraping, sanding) since sanding with a tool does provide a bit extra removed wood, so need to clean up, flatten and shape the frames. Still have enough wood so not a problem there.
Also, will continue with hand sanding to fill out cracks more carefully..
Happy modelling..
Happy modelling..
Good afternoon. The crack from the repaired frames will settle down nicely. Maybe Tobias’s suggestion of sawdust and PVa will sort these out as well. Looking great. Cheers Hrant
While taking some nice walk close to the old fish processing plant in Richmond BC, came across this little beauty, there were closing so I got an opportunity just to take few shots while they are still open. Next time... it is fishing boat in restoration phases...
