Le Soleil Royal ZHL Build Log [COMPLETED BUILD]
It drove me nuts for several weeks.
I haven't worked on it for a week because of this and inadequate amount of wale material. I did find some 2mm x 4mm walnut from a previous build. Maybe I'll paint it black. I also found some pawlonia 2mm x 4mm that I can use to build up the rail to help the fancy gold supports fit. I'll try it and show you how it works.
The only reason I didn't build the rails up is because I thought it would close things in. gilbert's looks great. (besides some of the pieces being upside down ;) )
I can see from this vantage point that you had the exact same problems as I on the stern galleries. I don't know if you could call it a problem, just a pain in the posterior. Glad to see you back.
There’s too much space between the lower two galleries. I know I made it even worse because I added the furthermost galleries before the side ones. So I had to add pieces of wood to make things work.
I haven't figured out the editing part yet.....Anyway,,, By the time you add all the "goodies", you can't see the screw ups.
Jay has the right idea.... should of duplicated this stuff.
