J Jos Joined Jan 7, 2018 Messages 82 Points 78 Location Belgium Jan 13, 2018 #1 A few possibilitys with paper. Greetings Jos.
Dida Joined Jun 23, 2013 Messages 97 Points 68 Location Sisak, Croatia Jan 27, 2018 #2 Is everthing on this tank made of paper?!
J Jos Joined Jan 7, 2018 Messages 82 Points 78 Location Belgium Jan 27, 2018 #3 Hoi Dida, Yes, except the antenna`s. Gr. Jos.
Dida Joined Jun 23, 2013 Messages 97 Points 68 Location Sisak, Croatia Jan 27, 2018 #4 Do you use the paper of different thickness? The model looks terrific, great!
J Jos Joined Jan 7, 2018 Messages 82 Points 78 Location Belgium Jan 28, 2018 #5 Hoi Dida, the short answer is yes, but often you need to laminate or use cardboard of different thicknes. Inside you need a frame, just like a schip, made of an sturdy material, for the most model`s you can buy a lasercut set. Gr. Jos.
Dida Joined Jun 23, 2013 Messages 97 Points 68 Location Sisak, Croatia Jan 28, 2018 #6 Thank you for the information. I am impressed with your work.
