20221111
Started work on the 3rd of the Model Airways WW I aero engines – the Mercedes 1917 F-1466-3A; a 6-cylinder in-line used on the Albatross.
Work actually began a couple of weeks ago but along with being sporadic I’ve been taking my time to paint the model as I go. I decided that I would build the model as a ‘teaching’ engine so the various major components are being painted in colors: oil system blue, water (coolant) system green, cylinders black, rocker bases/arms red, engine block/crankcase in silver (didn’t have any aluminum-colored paint in my stock), carburetor/intake system bronze. I also decided to paint the engine stand black.
Getting all the parts to fit properly has meant lots of file work. To paraphrase something I saw about Rolls-Royce back in the 1930s-40s - 'file it until it fits'.
The engine block/crankcase is in two parts that are held together by 00-90 bolts/washers/nuts. Very small threaded hardware; I used my locking tweezers as wrenches to tighten everything up. After I had the first two bolts in I thought (very briefly) that I maybe I should have tried to recreate the gasket that is between the two halves. It was just a thought that I tossed out. Once I had all the bolts in place and tightened, I added a drop of CA on the bolt of each one to keep them in place.
With the engine now sitting on the stand, work will turn to ancillary components – carburetor, air intake, rocker bases/arms, transmission, remaining parts of the coolant system, spark plugs…still a long list before getting to the propeller.
