Mini saw project
Hello everyone,
As we discussed earlier in another thread, I am currently designing a mini table saw, somewhat similar to the Byrnes saw. I hope that my design will be at least as good, and perhaps even better in some respects.
The table will be 400 mm wide and 325 mm deep. Unfortunately, I cannot make it any larger. The main limitation is that I don't have large machines in my workshop, so I simply cannot properly machine larger components.
The saw will run at around 5,500 RPM, but it will also have smooth variable speed control. I am planning to use a servo motor, which should allow the saw to maintain full power even at relatively low RPM. As I understand it, lower speeds can be useful when cutting plastics, as this helps prevent the material from melting.
The saw will also have precise blade height adjustment, allowing the blade to be raised or lowered, so that more or less of the blade can protrude above the table. I hope to make this adjustment as accurate as possible.
The saw will accept Proxxon 80 mm blades, as well as larger blades up to a maximum diameter of 100 mm, with a 20–22.2 mm bore.
At the rear there will also be a riving knife, which is not installed yet, as well as a dust extraction outlet.
For now, please take a look at what I have designed so far. I would really appreciate your comments, suggestions and constructive criticism.
I should just point out that I am working within some fairly strict limitations. I simply don't have the equipment to manufacture very large components, so I have to keep the overall size and dimensions within what I can realistically machine.
That's why the saw is going to be this size.
I'd be very interested to hear what you think.
Roman
Hallo zusammen,
Wie wir bereits in einem anderen Thread besprochen haben, entwerfe ich derzeit eine Mini-Tischkreissäge, die der Byrnes-Säge ähnelt. Ich hoffe, dass mein Entwurf mindestens genauso gut, in mancher Hinsicht vielleicht sogar besser sein wird.
Der Tisch wird 400 mm breit und 325 mm tief sein . Leider kann ich ihn nicht größer anfertigen. Der Hauptgrund dafür ist, dass ich in meiner Werkstatt keine großen Maschinen habe und daher größere Bauteile nicht ordnungsgemäß bearbeiten kann.
Die Säge wird mit etwa 5.500 U/min laufen , verfügt aber über eine stufenlose Drehzahlregelung . Ich plane den Einsatz eines Servomotors , der es der Säge ermöglichen sollte, auch bei relativ niedriger Drehzahl ihre volle Leistung zu erbringen. Meines Wissens sind niedrigere Drehzahlen beim Schneiden von Kunststoffen von Vorteil, da sie das Schmelzen des Materials verhindern.
Die Säge wird außerdem über eine präzise Höhenverstellung des Sägeblatts verfügen , sodass dieses angehoben oder abgesenkt werden kann und somit mehr oder weniger vom Sägeblatt über den Tisch hinausragt. Ich hoffe, diese Einstellung so genau wie möglich zu gestalten.
Die Säge ist für Proxxon 80 mm Sägeblätter sowie für größere Sägeblätter bis zu einem maximalen Durchmesser von 100 mm mit einer Bohrung von 20–22,2 mm geeignet .
Hinten befindet sich außerdem ein Spaltkeil , der noch nicht montiert ist, sowie ein Staubabsauganschluss .
Werfen Sie bitte zunächst einen Blick auf meine bisherigen Entwürfe. Ich freue mich über Ihre Kommentare, Anregungen und konstruktive Kritik.
Ich möchte darauf hinweisen, dass ich unter recht strengen Einschränkungen arbeite. Mir fehlt schlichtweg die Ausrüstung, um sehr große Bauteile herzustellen, daher muss ich die Gesamtgröße und -abmessungen im Rahmen dessen halten, was ich realistischerweise bearbeiten kann.
Deshalb wird die Säge diese Größe haben.
Ich wäre sehr daran interessiert, Ihre Meinung dazu zu hören.
Roman
Hallo,
Zuerst Danke für deine Mühe und bisherige Arbeit. Mich würde interessieren, wie der Längs-und Queranschlag geführt und eingestellt wird, bzw angedacht ist.
Hallo,
die Querführung läuft auf Linearwellen mit Linearlagern und lässt sich dadurch sehr leicht und präzise bewegen.
Der Längsanschlag ist dagegen fest montiert, kann aber bei Bedarf abgeschraubt und komplett demontiert werden. Auf der linken Seite ist außerdem eine Nut vorgesehen. Zum Lieferumfang gehört auch ein Winkelanschlag für präzise Querschnitte bzw. Schnitte in verschiedenen Winkeln.
Zusätzlich wird ein Anschlag mit Mikrometerschraube im Lieferumfang enthalten sein. Damit lässt sich der Längsanschlag sehr präzise verstellen und positionieren
Hello,
the crosscut guide runs on linear shafts with linear bearings, so it moves very smoothly and precisely.
The rip fence, on the other hand, is mounted firmly, but it can be unscrewed and completely removed if necessary. There is also a slot provided on the left side. The set will also include an angle gauge for making precise crosscuts and cuts at different angles.
Additionally, the set will include a stop with a micrometer adjustment, which will allow the rip fence to be moved and positioned very precisely.
Proxxon blades tend to distort when cutting larger wood thickness. This results with uneven and burned cuts. This is more evident with larger diameter and thinner blades. Ensure the blades are clamped between much larger diameter and thick hardened steel surfaces compared to Proxxon.
Extend the blade out and press on its side with your fingers. Blade must not bend at all. Whole blade mounting module must be very robust including blade shaft.
I have found the slot to the right of the blade handy on my Byrnes saw.
The angle gauge isn’t really set up for cutting stuff to the right of the blade but you can make do with it.
Good luck with this.
A good little table saw is a beautiful tool to have.
The table size is a bit larger than Proxxon so it is good enough. You could’ve done it exactly the Proxxon size and it still would be perfect. You are making a mini saw are not you?
I suggest you compare specs with mini saws already available such as the Model Expo Mini Table Saw
SKU:MET1104 (currently for sale at $59) to be sure you are competitive in the market. Just a thought. :)
