Mini Square
I’m looking for the small triangular square I have seen that others have. It’s maybe 2”x 2” on the right angle.
Thanks for the help in advance.
I have a set of machinist squares and love them but for really small squares, Lego blocks work very well on edge or laying flat. My grandkids gave me a few pieces from their sets when they were really young and I have been using them on occasion for over 10 years.
As Allan suggested the lego block are great for squaring and holding the bulkheads in place as they dry.
And as Russ and Corsair suggest the 1,2,3, blocks are inexpensive and have a lot of uses. Here is am using one to weigh down a deck being glued into place.
Rob
"There's a tool for that." department:
While I have a number of small model-makers' machinists' squares, the one I use far more often that the rest by far is a MicroMark "thin beam" square. They cost about $20, but I got mine when they were a "loss leader" on sale for much less. The MicroMark catalog shows them as out of stock at the moment, but it's the sort of tool that is probably made in China and sold by a lot of other people, besides MicroMark. They also make a 45-degree thin beam "square."
The pictures below clearly show the advantage of the thin beam. With the sizes of material we regularly use modeling ships, the usual squares have much thicker beams and thus require a "lifting piece" below the workpiece to provide the clearance necessary to get the blade to lay flat on the workpiece in order to strike a straight line with a pencil or knife. If you are going to only buy one machinists' square for modeling, this would be the one to get. I enjoy having my thick beamed squares and they do have their uses, especially when used on their beam ends which keep the blade standing straight, but for the tasks pictured below, which ship modelers and model railroaders perform far more frequently, there's no substitute for a thin beam square.
