When I received this kit the previous owner had started to assemble the frame. I disassembled the frame for shipping by using acetone to loosen the glue. I then cleaned and sanded the parts but there are some minor imperfections that should not be visible after the ship is assembled (please see the image with the frame pieces). I did an inventory to make sure that all of the contents of the kit were present but PLEASE REVIEW ALLPICTURES, what you see is what you get.
Model Shipways Charles Morgan Whale Bark Wooden Ship Scale 1:64 Kit #MS2140 - Made in USA
Length: 30-3/4" Height: 25" Width: 9-5/8"
Kit Includes:
Plank-on-bulkhead construction, laser cut basswood for the hull components. Wooden bow and stern filler blocks help you shape the real ship. 75 feet of copper sheathing to cover the hull below the waterline. Wooden yards and mast, 140 deadeyes in three sizes, nearly 200 single and double blocks, four diameters of black standing rigging and two of tan running rigging duplicate the rig plan of the original whaler. An assortment of fine metal fitting includes brass ship's bell, Belaying Pins, eyebolts, spilt rings, strips, wire and chain, anchors, bilge pump, chocks, cleats, fire door, chimney, and galley stack. Seven whaleboats are to be assembled from laser cut wooden parts. (Display base and pedestals not included.) Six sheets of detailed plans and 40 page step-by-step instruction manual
Kit Includes:
