I am adding to Jimsky's Tool List - This is a rather large list and I am sure that others will be adding to it. This will give you some ideas.
6" Ratchet Bar Clamp/Spreader
6-pc. Mini Spring Clamp Set
Model Makers Hemostat Set
Hull Planking Clamp set
Alligator Clamps, Insulated, With 1/2" Jaws
Vises of various sizes.
Mechanical Pencils
Colored Pencils
Highlighters
Digital Caliper
Stainless Steel ruler
Ruler with 0 center marking
Solid Steel Jewelers Block
Drill Bit set from .1mm to 2mm
Drill Bit set from 1/16" to 1/4"
Exacto Knife set with #5 handle
Clamp-on Magnifying lamp with Fluorescent bulb
Metal Triangle
3" Machinist Square
6" Machinist Square
Variable Speed Rotary cordless tool
Rotary tool assortment
Bees Wax
Picks and probes
mini plier set, cutter, nippers, long nose pliers
Mini Hand Plane
Tweezer set
Midwest Miter Box with Saw
Pin Vise
Mandrels
Hobby Hammer
Paintbrush set
Diamond Needle file set
Sandpaper
Very small scissors
Wood Glue
Cyanoacrylate (CA) glue
Epoxy
Assorted sizes of wood dowels, small planks to make jigs and fixtures.
Disk Sander
Disk grinder-buffer
Mini Drill Press
Scroll Saw
Band Saw
Mini table saw
Lathe
Mechanical Pencils
Colored Pencils
Highlighters
Digital Caliper
Metal Triangle
3" Machinist Square
6" Machinist Square
Bees Wax
Picks and probes
Mini Hand Plane
Tweezer set
Pin Vise
Mandrels
Hobby Hammer
Paintbrush set
Sandpaper
Very small scissors
Wood Glue
Epoxy
Disk Sander
Disk grinder-buffer
Mini Drill Press
Scroll Saw
Band Saw
Mini table saw
Lathe
