Need help identifying this sanding tool.
Bryian
Forum Moderator
Phillip Island Australia
Hi gang,
I need to purchase another rubber mandrel hook and loop style sanding attachment for my Dremel.
Its about 20 mm diameter and has velcro/ hook and loop sanding discs. I can only find large sizes on the net.
Thanks in advance, cheers Brian.
YES THIS IS WHAT I GOT, THE FIRST TIME I TRIED IT THE SHAFT BENT, it happened to a lot of people, what the said to do is chuck it as far as it could go and run at low speeds, since then they have com out with the small shank like above have not really tried it yet, but will soon i have both the 1 inch and the 2 inch, i do not see much use for the 2 inch but who knows. GOD BLESS STAY SAFE Don
I have ordered the yellow sanding pad as shown by Sea Burd, thank you.
I note the comment from Don that the shank is thin and bends easily.
In Jan here, we have the first Auto Swap of the year, it’s indoors, the booths with sand/ polish stuff are in every row. I loaded up for my DA sanders and the 3m Velcro on pad. Now I’ll be looking for these small ones, thanks!
