Norwegian Sailing Pram 1:12 by Roscoe [COMPLETED BUILD]
Thanks Rob.
I have finished my Pram and am very happy with the way it turned out.
The timing was perfect, we leave for home tomorrow after being gone for 4 months.
This hobby has worked great for me being on the road and retired. My shipyard was a little cramped in the camper but it worked okay. I finished my first two boats in 3 months and am obsessed with it. My problem now will be wanting to work on the next one after we get home but not having the time like I have now.
I have the last model in this series and will be starting it in a couple of weeks.
I will be doing a build log for The Moscongus Bay Lobster Smack from my home in Wisconsin.
Thanks for all the feedback from this forum.
Roscoe
I have finished the mast, boom, and gaff. As others have mentioned, they came out more oval than round but I am okay with this. I ended up breaking the tip off the gaff also as mentioned by others. The break is not noticeable after I glued it back together. I also worked on the sail. The instructions say to use diluted glue and paint the material. I choose to use Modge Podge. I taped the material to my cutting mat and applied the modge podge and when I pulled it off I was not real happy with the outcome. The side I applied the glue to left a texture on the material which I like, but the underside against the cutting mat left a smooth glossy finish which I don't care for this look so I will not do it this way in the future. I should have tested this process first before jumping off the dock, so I will live with the outcome. I also shaped the oars, This went much better than the oars for the Dory I did, but I think they are bigger. I used the mast jig and that worked very well to start the shaping.
Tomorrow I hope to start lashing the sail.
I think I am getting very close to finishing this one.
Congratulations also from my side for finishing this project - Very well done :cool:
I too found that a perfectly round mast was not going to happen, but I’m satisfied the way it came out. Those little “straps” were hard, especially after cutting the “bolts” really short. I wish I had smaller fingers!
Larro, Your bolts look excellent, I ended up using a piece of the brass rod then peened both ends.
Thanks Rob.
View attachment 438764View attachment 438765
Roscoe
I'm currently working on the same model. Struggling with the metal hardware, though. The bolts provided with the kit are way too thick to fit through the holes in the stay plates, etc.
Hallo @Donnie R
How is your work going on the model?
Hallo @Roscoe hope it is ok suing your thread for the greetings
Hallo @Donnie R
I had the same problem. I had smaller bolts from a previous build that I used instead, throughout the entire build.
