Amerigo Vespucci 1:84 by Panart?Mantua Build – RC Enabled
Holy Moly JJ, I can't wait for this build! But I have to admit that you lost me in stage one - propulsion. What is your background, EE, ME, physicist, nuclear?? I really look forward to this build as I'm sure I will learn a lot. I'm in the front row. Magic Mike
Hi Mike,
Yes, I’m an E-Eng (Retired), primarily the energy sector (including nuclear). My area of specialization is industrial automation.
That aside, I’ve been a scratch model builder for years, although my area of interest was always RC aircraft.
Recently joined an RC sailing club so I’ve been building IOM’s. Sadly, wood boats are generally not competitive in this class.
The Vespucci offers so may challenges… I’m sure it will keep me entertained.
Cheers,
JJ…
Hi Mike,
Cheers,
JJ…
Nice Storch !
A word about planking…. much like war, your planking plan doesn’t survive its first contact with the wood….;)
And that couldn’t be truer for the Vespucci. I’ve planked my share of models, however it’s obvious the design planking for this ship would not hold up to real life use, specifically the aft end which is much too fragile to hold up to the rigours of RC sailing.
To that end, I elected to balsa-fill the stern of the ship to offer greater surface area for the planks to anchor. It added a full day to the build, however I’m confident the effort will pay dividends.
View attachment 528204View attachment 528205
Hi JJ
Indeed it makes total sense to have balsa fill at stern and bow
Best
Sorry about the delayed report... been focused on the base layer planking.
I'll need a couple of days to complete the block-sanding and application of the filler (a task best performed outdoors).
Upon which I'll tackle the second plank layer.
A word on waterproofing.
While ultimate hull waterproofing will be achieved with the final fiberglass/resin application, it's advised to add sealer at critical joints during the assembly process.
Gorilla expanding foam adhesive is an excellent product for this purpose. During its curing process, it expands into all cavities and hardens into a waterproof seal. I should also note that it's an exceptional adhesive in its own right.
Following a minor rain delay, I managed to complete the block sanding of the first planking layer.
I can see why some have elected to forgo the second planking layer for this model.
However as this will be a runner, I need the additional strength offered by the second layer....so here we go.
J.J., your planking results are fantastic! Nicely done, Magic Mike
I’ve planked a few IOM’s in the past, however they were all single layer using 2.5mm red cedar. And given the complex curves, a steamer was required to encourage the planks to take shape.
This AV uses 1.5mm lime wood for its base plank, and 1mm (what appears to be Walnut) for the second layer… a pity really as the hull would be very pretty varnished as apposed to painting.
As mentioned earlier, plank on plank requires some creative solutions to apply satisfactorily.
