**VIEW THREAD HERE** |
I don't (personally) understand. Are you looking for places to buy milling strips for planking?i need strip planking.
I email them a order there didn't have what i was looking for i need 0.6+5+320 in natural. There have 06 x 6 mm planking in walnut. i guess in stock.do you no any other sluppy house, thank you.For starters, Model Expo has planking strips.
in 'natural' what? Natural pear, walnut. basswood, boxwood? just wondering.....I email them a order there didn't have what i was looking for i need 0.6+5+320 in natural. There have 06 x 6 mm planking in walnut. i guess in stock.do you no any other sluppy house, thank you.
in natural wood,in 'natural' what? Natural pear, walnut. basswood, boxwood? just wondering.....
thanks
OK..having worked in wood for nearly 60 years, wood being called 'natural' is a normal yhing to do as long as you are referring to each species as being unfinished. Fresh cut lumber, regardless of species is in its natural state. Now in modelling, there are quite a few different species used by builders and suppliers for thir ships. Note that basswood and boxwood, when it comes to color, can look very similar. This might help when purchasing wood stock for a model when it comes to pricing. We're here to help and each of us needs assistance from time to time. I am not trying to chastise you, rather trying to give you some understanding. Are you building a kit? Building from scratch? Kits typically have basswood components as well as mahogany (sapele too) and plywoods. Give us more information so we can better help you! And you can post pictures if need be.in natural wood,
ZHL in China sells a variety of plank sizes through AliExpress. Choose your size.I email them a order there didn't have what i was looking for i need 0.6+5+320 in natural. There have 06 x 6 mm planking in walnut. i guess in stock.do you no any other sluppy house, thank you.
Those numbers make no sense to me.is 0.6+5mm same as 1/16 1/16
YESS i doYou have the Occre kit #12500. Do you have the wood strips that are 0.6mm thick x 5mm wide? The 320mm length means that this is the length for the the deck boards per the instructions. Hope this helps.
yess i doYou have the Occre kit #12500. Do you have the wood strips that are 0.6mm thick x 5mm wide? The 320mm length means that this is the length for the the deck boards per the instructions. Hope this helps.
i don't think there gave me enough.Very good. These same boards will also be used for other steps in your build, again per the instructions. You just need to cut them to the length stated from the kit supply. Why do you need to order more from Occure? Did they not supply enough?
