Polacca-Sciabecco franceze Mistique [COMPLETED BUILD]
While the construction site froze.I deal with gun port covers.Who knows where to buy the fittings and decor of the models of Korel?Where I took cornwallmodelboats is not available.I don't know when they will be.
Started a war with the rigging.Set the foremast, bowsprit.Pulled the bowsprit with backstage.Pulled up the foremast.Now a question about blocks for the main-yard halyards.For the main-yard, two blocks are assumed.And for the Sten-main-yard one is drawn on the plan.What should I do?Maybe they just forgot to draw the second block.Or the root end of the mainstay halyard is attached directly to the mainmast.IMG_20200519_151041.jpgIMG_20200519_151047.jpgIMG_20200519_151114.jpgIMG_20200519_151118.jpgIMG_20200519_151041.jpgIMG_20200519_151047.jpgIMG_20200519_151114.jpgIMG_20200519_151118.jpgIMG_20200519_151138.jpgIMG_20200519_151211.jpgIMG_20200519_151217.jpgIMG_20200519_151309.jpgIMG_20200519_151347.jpg
This is an independent building.At the beginning of the topic, I wrote about this.I ordered blocks and uppers separately.The ropes are wound independently.
Инерции на все не хватает. И модель надо строить, и про жену не забывать, а также лето в разгаре, открыт дачный сезон. Всё надо полить, собрать, обработать.
Inertia for everything is not enough. And the model needs to be built, and one should not forget about the wife, as well as the summer in full swing, the summer season is open. Everything needs to be watered, collected, processed.
IMG_20200618_201207.jpgIMG_20200618_201214.jpgIMG_20200618_201228.jpgIMG_20200618_201243.jpgIMG_20200618_201253.jpgIMG_20200618_201318.jpg
hi guys.I will continue the story of the construction of the Misticque.Changes little,because of illness,hernia of the spine in the neck.My hand is numb.So far, this is what the model looks like.I'm being treated.Painted the bulwark and bulkhead inside.Set the hatch and bollards.I started making carriages.I'm waiting for a package from Amati with all the little things.
Beautiful and highly detailed accurate work that shows a lot of hours and patience. God grant me the same. PT-2
