In Germany and Austria the Ponal Express wood glue is the standard water based wood glue
I guess most of the modelers here are using this glue - also myself
Dry after some minutes, but definitely enough time to correct if necessary
the glue is white, so you can see very good surplus, which you can remove with a chisel etc. - when it is dry the glue is transparent
You can reopen joints relatively easily with drops of water, which I needed already several times.
This glue is my standard wood glue
