Preac saw blades
I used to purchase blades for my Preac saw from Thurston. They are no longer in business being sold to Malco Saw blades. They require a minimum of $100 purchase. Does anyone know where I can purchase Preac saw blades?
What is the diameter and arbor size? From that information you can find other blades that will fit.
Slow period at work.. The Preac blades are 2 1/4 inch diameter with a 5/8" bore. This place sells what look like standard slitting saw blades:
Not too bad a price, but there are more options from an industrial supply house:
There is a lot of Preac chatter on dollhouse and model railroad boards- you should be able to find some suggestions there, and maybe someone has found a trim saw that uses a 5/8" arbor and a blade made for cutting wood? These seem like very nice little saws!
Hello Barry,
I have used Preac saws (small and large table version) for as long as Preac was in business on Long Island, NY (which is where I grew up although I never visited the facility). Apparently no one in the family or anyone else associated with the the company decided to take over the business. It's a great saw for milling/cutting smaller stock for ship modelling but it is somewhat under powered. Bob Prezioso of shipahoymodels.com offers a 1/3 HP motor upgrade which I now use on all of my Preac saws which has increased the versatility of the saw tremendously. Bob also makes a very good disc sander. The high quality Byrnes table saw is great saw for "larger scale" work. The only advantage a MicroMark has is that you can tilt the blade. As for blades- I purchased a 2&1/4" solid carbide blade with 5/8" arbor from Southern Carbide Specialists, Inc., Quitman, GA (socarb.com) 5 years ago and it's still going strong! In my opinion solid carbide blades, although more expensive, do a better job and last far longer than HSS blades which tend to overheat. A Preac with an upgraded 1/3 HP motor and solid carbide blade is the ultimate in precision small scale milling. There are other companies that make solid carbide blades: Johnson Carbide Products (johnsoncarbide.com) and Malco Saw Company (malcosaw.com) which you mentioned but I haven't had to buy another one in 5 years!
