Raúl Ramos Blandford Cross Section Build
Mike41
Well-Known Member
Blandford Group Build
Nice work Raul, you are off to a great start.
Mike
donfarr
Well-Known Member
WELCOME TO THE BUILD RAUL good to have another build to look at YOUR CRAFTMANSHIP IS MUCH BETTER THEN MINE, but i keep on trying and getting better all the time. Don
zoly99sask
Well-Known Member
Administrative
Hello Ramos,can you repost the image,not visible,thanks!!
dj56
Well-Known Member
Muy bien hecho Raul
un salu2
willy
donfarr
Well-Known Member
Hi RAUL, LOVE YOUR BUILD EXCELLENT WORK, REALLY NICE, I HAVE A REQUEST WHEN YOU GET TO THE MAIN DECK BEAMS COULD YOU POST SOME PICTURES ON HOW YOU GOT THE CAMBER AND CUT OUT THE BEAMS, WOULD APPRECIATE IT. THANKS Don
Raúl Ramos
New Member
Chile, Ciudad de Punta Arenas
Hola, donfarr, gracias, es el primer ensayo con planos y quise partir por esto ya tienes todo y estoy experimentando, respecto a tu consulta no tengo fotos de esa etapa en la rebaja la viga maestra a medio espesor para asentarla. la primera cubierta cambiare rebajando la viga de soporte en el grosor completo de la viga maestra cuando esté en esa etapa puedo mandar fotos que creo será la próxima semana. lo mismo cambiare la forma de realizar los enjaretados ce no quedaron muy decentes.
atte.
R. Ramos A
Hi, donfarr, thank you, it's the first rehearsal with plans and I wanted to leave because of this you already have everything and I'm experimenting. Regarding your query, I do not have photos of that stage in the recess the master beam at medium thickness to seat it. the first cover will change by lowering the support beam in the full thickness of the master beam when it is in that stage I can send photos that I think will be next week. the same will change the way of making the enjaretados ce not very decent.
Atte.
R. Ramos A
donfarr
Well-Known Member
Thanks RAUL, LOOKING FOREWARD TO THE PICTURES OF MAIN DECK BEAMS. Don
