- Jan 5, 2025
I started building the RMS Mauritania from the 1:600 airfix kit.
Yesterday, as I was progressing with my build, I noticed that the paint diagram was different than the reference photos that I was working with. In the Airfix instructions, they show a thicker white line at the water line then it probably should be.
I tried going back and making the line thinner, but it’s harder to make lines straight after the fact.
Please take a look at the following pictures and let me know if I should go back and try to fix it by repainting the hull. The risk is that I’ve already laid down several coats of paint. I’m afraid it’s getting kind of thick.
I need to decide if I need to fix it or if I should continue because I need to start adding the decks now with the railings in place.
