Royal William Euromodel 1:72 by Vince P.
Vpirozzi
Well-Known Member
Finishing up with adding the remainder of the head rails. After placing the rails, I noticed that the top rail was curved so that it was way out from the lower rails. This would make the head timbers uneven and at a impractical angle. I had to remove the top rails and completely re-bend them so they followed the curve of the lower rails more closely. Since they were already painted, using a torch was not a good idea. I had to bend them by hand, very carefully and slowly so as not to break them. The last photo shows the top rail hugging the hull more closely. Another mistake I learned from. Installing the rails from the bottom up would make more sense.
Vince P. Ship-1
Vpirozzi
Well-Known Member
OK, a question for all Royal William builders. See the attached photo.... It is a metal part included in the Euro kit with a number of "11155". What is it?? Can't find anything on the plans or drawings even mentioning this. I believe it has something to do with the bow ornaments since the number is in the sequence for the parts there. HELP!
Vince P. Ship-1
Vpirozzi
Well-Known Member
Keith, Vince, Mark - mystery piece 11155 for the RW is not a mystery. It is the final extension of the top head rail at the bow. The side view and top views show this. Depending how your build goes, it might be included, thinned down or omitted.
Pete
OK, now I see where it goes. At the end of where the top rails join on top of the stem, there is a little swirl added. That is this piece.
I will add it. Thanks Pete.
Vince P. Ship-1
Vpirozzi
Well-Known Member
Placed the gratings inside the head rails. As was already pointed out, they are lower than the drawings show because the curvature of the upper head rails is a little too low. I am however not too disturbed by this. Since my build log seems to be ahead of the others, I am the one who will make some mistakes for others to benefit. That is why build logs are so important, and one of the reasons I stick my neck out and publish my work for others to see.
Vince P. Ship-1
Vpirozzi
Well-Known Member
I have placed the timbers between the rails on the starboard side. I did not use the metal strips supplied in the kit, although they are fine. I made some decorative strips with wood from my stash and milled out the center by hand. I think they look more like the drawings and of other high quality models I have seen around.
I found another blunder after placing some of the timbers at the forward end of the rails. When I bent the outward curves into the rails, I tried to match the drawings, and think I came pretty close, BUT, the stem is too thick and too high as provided in the kit. There is no room for the gammoning ropes to fit in between the inside of the lower rails and the stem. I would have to have known to shave the thickness of the stem piece, or cut it way down from the top beforehand. In looking at some scratch built models, the stem piece is cut way lower from the top to allow the ropes to run between. Nowhere in the plans does this seem obvious, but someone smarter than me would probably catch this. Anyway, if you are following this log, you can avoid this by fixing it before placing the lower head rails. I will have to run the gammoning outside the rails at the lower end and then feed them up inside to the bowsprit. I have seen other ships of the period do this, but not the RW.
Vince P. Ship-1
Vpirozzi
Well-Known Member
Now that the bow is mostly finished I decided to finish placing the trennels all along the unpainted portions of the hull. This will take a while since there are hundreds of them. Like before, I am using round toothpicks.
Vince P. Ship-1
Vpirozzi
Well-Known Member
I have placed the forward forecastle bulwark and railing, as well as the catheads. The metal pieces supplied in the kit worked out fine. Once I join this railing with the forecastle side railings, it will look very nice. I will construct and place the side railings next.
Vince P. Ship-1
Vpirozzi
Well-Known Member
The cap rails on top of the bulwarks that run the length of the entire ship except the poop deck are completed. This was a tedious task since they are made from scratch with many little pieces. All of the parts including the little vertical support posts, the railings, and the bits on the forecastle are made from 4mm x 1mm walnut stock. The only exception are the railings that have the sharp curves at the ends. In order to make the bending easier, I used 2 strips of 4mm x 0.5mm walnut and laminated them on top of each other after bending, to form the 1mm thickness.
Now I will start at the bow and work on all of the deck fixtures and structures from stem to stern. This part of the build will take a long time.
Vince P. Ship-1
Vpirozzi
Well-Known Member
Some more little progress.
1. I added the little cleat to the stem for the first gammoning rope. I originally overlooked this and cut a hole in the stem for the rope. Once I saw my mistake, I filled in the hole and created the cleat.
2. The 2 knights are added to the prow deck. They are pinned in place.
3. The forecastle fife rail and knights around the foremast are added. They are also pinned in place. As mentioned before, I decided to add the belay pins to the rail. The original RW probably did not have them, but a later rebuild would have had them added.
I am now proceeding to the breast rail for the forecastle deck. The plans do not show the rail or mention any dimensions. I asked Pete of Euromodel for some help here. His notes do show a diagram of the railing but no dimensions. He informed me that help is forthcoming.
Vpirozzi
Well-Known Member
The forecastle breast rail constructed and installed.
A big thanks to PiratePete of Euromodel for his photos and instructions. The plans are severely lacking in what this structure looks like or how to build it. I used his information and modified it slightly to come up with what I think the rail should look like.
Vince P. Ship-1
pict0435.jpg pict0436.jpg pict0437.jpg pict0438.jpg pict0439.jpg pict0440.jpg pict0441.jpg pict0442.jpg pict0443.jpg pict0444.jpg
Vpirozzi
Well-Known Member
The main deck capstan is installed. The one provided in the kit is 15mm in diameter and 20mm tall. The diameter is right, but the height is too tall. Not only does it just barely fit under the forecastle breast beam, by scale it would have been too tall for the crew. The plans call for a height of 15mm, which is just about right. I just cut off 5mm from the center spindle and glued it back together. That preserved the shape of the base and curved top. Since I am rigging her in full sail, this would represent a working deck, so the arms for the capstan would not be in place. I stored them on the deck next to the capstan.
Next up is to build and install the main deck guns, so that things like the gangways and ladders can be placed. These will hamper access to the guns for installing the rigging and such.
Vpirozzi
Well-Known Member
Working on the main deck guns. Many tiny parts have to be made and assembled. I tried to go into the most detail by including parts like the quions and wheel spikes, all of which had to be made from scratch. All of the shiny brass pieces were blackened to give a more realistic look. The last photo shows all of the pieces ready to assemble into the guns.
Vince P. Ship-1
