Russian torpedo boat KIT1899 or teaching modelbuilding
Hello friends
here a view aside towards my tabletop buildings in 28mm or 1/56 to show where time is also invested for modelbuilding:
Light Brown aquarellic paper with impressed lines and a repeated light touch of high quality water colour. This is my testbed for colouring the models keeping the colour in placed.
The Combination of the copied parts eats up a lot of time and so I will reconstruct only one side copying it to the mirrowed side.
If this sentence does make any sense at all.
I decided to enlarged the drawings by 312% to get my 1/64 parts in one piece, the errors are piling Up to inaceptable numbers! :-/
Back from the Copy Shop and invested into ink drawings:
so the lines do stay straight (as a laser xerox does warm the paper and it is wrapping in all directions when cooling) and I cut the DIN A0 sheet into manageable sections on an "under light table" with a wheel cutter:
So now we can restart the boat of the safe side...
So up she goes - and I can trust into this drawings enlarged by 312% from 1:200 into 1/64 scale.
Today I figured out my work bench is on it's length's limitation! So here we are with the centerboard
39"/990mm at all - I have to take away a storage box.
Hello friends, today was a day of a good progress: dealing with the centerboard from 2mms book binder card board was the job. I did use spray canned glue with a good result. I decided to cut it in half for easier handling What you do see is my hole work bench in the very background a cactus terrarium.
A little bit of progress:
I.
As I failed to glue the tip of the ram with cardboard somehow as the spray clue does bond too quickly!
IMG_20250818_110401_550.jpg - so I fixed this by additional cardboard:
II.
Cutting 20mms from the CWL on the bulkheads to the lines of my baseplate - by this I can deal with clear acrylic for the water later on:IMG-20250818-WA0000.jpeg
Hello friends,
due to the price of transparent acryl I decided to move my cut up towards the CWL and have altered the centerboard and it looks quite right:
...and orientated the bulkheads glueing them towards the outside mechanical made edge as I learned in here:
As I wanted to give spray glue from the can a "Go!" I was very happe with it's possibility to arrange the parts for some seconds - but now I have to wait 24hs untill it is completly bond and dry to the touch.
So today was a great day fighting depression!
No big progress I just cut out the bulkheads
and am awaiting my purchase of the 1mm bookbinder cardboard so I can clad them onto the 2mm I do have - so the slots in the drawings can be used as they are...
Hello friends,
today a little bit of progress to the bulkheads - all outlines cut out:
...and all these glued onto one millimeter cardboard:
All the slots will be cut with a chisel in the next step.
Best wishes from Berlin C-H
