San Bartolomé - Pavel Nikitin [COMPLETED BUILD]
Thanks Freddie. I did use all four pieces I had available, as I seem to remember that testing before gluing was the best way to get it to the rounded shape I wanted. In any case, you have to shape it with sandpaper afterwards, so in my opinion it's always better to have some wood left over. I hope you enjoy the project as much as I did. I hope the translator did a good job.
Gracias Freddie. Efectivamente, utilicé las cuatro piezas de las que disponía, pues creo recordar que haciendo pruebas antes de encolar era lo mas conveniente para que quedase de la forma redondeada que deseaba. En cualquier caso, después hay que darle forma con papel de lija, por lo que según mi criterio, siempre es mejor que haya madera de sobra. Espero que disfrutes con el proyecto como lo hice yo. Espero que el traductor haya hecho bien su tabajo
Thanks for the quick reply. I will go ahead with the 4 pieces. The translator worked great!
I am back a second time to again thank you for the excellent pictures. Do you have the time to tell me in detail exactly which of Pavels paints you used and in what sequence and how you applied them? You have perfectly achieved the same result that Pavel did. I am trying and failing! I'm just not getting it . . .
Many thanks and with great respect
John
Hi John, I just followed Pavel Nikitin's instructions. If you Google "Pavel Nikitin Masterclass," you'll find a video showing how he does it.
John
But I made a few mistakes at first. First, we apply the black or patina, then we sand, but we sand very well, leaving the wood almost natural and the black only injecting the wood grain and into the joints and crevices. Afterwards, in my case, I only used oak stain.
Thank you for that info. I had seen the video but since I was having trouble with coloring, which he didn't specifically mention, I was hoping to get that info from you. So now I have it - many thanks.
I am thinking about using colors instead - this is attractive to me !
Very nice model and great workmanship. I ordered a "San Bartolome" two weeks ago and cannot wait to get started.
