Scale blocks available in UK
Just a heads up for builders in uk looking for better blocks than provided in most kits. Just had some samples from Modelnet.co.uk. They generally produce blocks from 3mm-6mm but will do others on request. I was after all of the above plus 2mm and 7mm in various single double and triple. not only did they provide me with samples in 3-6mm but also produced some samples in 2mm and 7mm. basically they will produce other sizes to order. samples were sent on 23rd and I received them on 26th December. I'm well happy with the quality and thought others may benefit. they come in strips of 10 and range from about £1.20 to £1.60 per strip depending on size. not the best photo but a picture of 7mm tripleIMG_20241228_144223.jpg
