Schifetto Carlofortino - in scale 1:20
the leudo is a typical Ligurian boat much larger at least 18-20 m the wood is Swiss pear, but then it will be painted. the beams of the beams until only supported, then they are corrected, aligned and then glued and afterwards they made the cabin and the motor housing
these photos are of a Carlofortino boat built on the island of San Pietro in the early 1900s and motorized in 1927 used for trade and then for the transport of minerals the photos are from 35 years ago today it no longer exists because it was destroyed by a fireC5305378-160E-4AE8-A9FE-B52C68B01742.jpegCF6A9007-4B56-463A-8028-A38365DE6615.jpeg9FFBAF21-32DB-41ED-9E4B-EE19A6995790.jpegB1C6D7AD-0209-4C1E-927A-FFA644F0BD23.jpeg0F0AEBE4-D4BE-496A-9F60-27022A256A16.jpeg2869D6C4-83BB-4B6D-BCF5-588FBCCCCE64.jpegD9C49B52-89B6-44B5-A906-758D41E71BA1.jpeg746851B9-339A-4E3D-A2AA-A33C0980ACA2.jpeg
the keel of the boat was 18 m long, it was called Gina and was very similar to a Leudo in fact the inhabitants of Carloforte came to the island from Liguria and the colonies of Tabarka in 1700
Some parts of the starter, the wiring and the muffler with the exhaust are still missing.
After the top is treated with a tamyia gray primer, then filled and treated with white primer and then painted.
Thus it will be possible to take the exact measurements for the shaft line and the assembly of the propeller and the bridge with the motor housing.
I can fully underline and repeat the words by Jim.
Somehow it is a pity to cover the beautiful timber with white and green paint - But it is technically and historical correct
So I hope, that there will be on the deck enough unpainted deckhouses etc. ...... ;)
Very good work Thumbsup
The model will be covered and painted with antifouling as the photo of the " Mamma Rosa" , and will have mahogany sides. Through the hatch of the cabin it will be possible to see the interior. I would like to make a diorama with a shipyard and insert this model together with one under construction where you can see the frames on sight.IMG_0340.jpgIMG_0341.jpgIMG_0343.jpgIMG_0346.jpgIMG_0347.jpgIMG_0348.jpg
This sounds very good - great idea Thumbs-Up
I've stocked up on lumber. Here in Italy you don't find much. In the past I bought from Crown Timberyard which has now closed or from Lumberyard. Browsing the net I found this site:
which has excellent quality and I took several woods I will have to square them but I have equipped myself with a new circular saw and I will finish with the small ones I had already purchased.
I made the structure in pear wood. I covered with some pear wood veneer. Then I covered with mahogany wood. Between one table and another I inserted some black cardboard. Then I'll proceed with the holesIMG_0427.jpgIMG_0429.jpgIMG_0431.jpgIMG_0432.jpgIMG_0433.jpgIMG_0435.jpgIMG_0438.jpgIMG_0440.jpgIMG_0441.jpgIMG_0446.jpgIMG_0449.jpgIMG_0451.jpgIMG_0452.jpgIMG_0454.jpg
