Scottish Maid (AL) - Rigging
  • Thread starter Thread starter Pwh
  • Watchers Watchers 1
Pwh
ottawa,ontario,canada
I have a problem with tracing how one of the lines is connected from the bowsprit to hull. I've attached a couple of pictures. It looks like two single blocks but I can't follow the path of the line. It looks like the line from the bowsprit loops around the lower block then loops over the upper block and then directly connects to the hull which doesn't make sense. Or the line from the bowsprit is connected to the upper block. Another line loops around the lower and upper blocks and then directly connected to the hull. This is my 2nd build. Trying to trace the lines is challenging enough. In a perfect world, the lines would be color coded on the plan. I would appreciate a simple diagram explaining the connections.
The way they are showing it is that the line comes from the bottom of the block that is attached to the rope coming from the bowsprit, it then goes through the single block that is attached to the hull back through the first single block and then it is tied off to where the single block is attached to the hull, hope this makes sense,
best regards John,
