Thanks Kurt. I've been using a shared scroll saw at our community workshop but too many people misusing it and I find I'm doing more maintenance than sawing.Have fun with it, do some practice before real work to get feel of handling wood.
Also ensure you hook suction vacuum hose to opening for dust collection, and it helps keep work piece and work area clean.
It looks to have a work area light, but ensure you have adequate light to see work, as it get dusty quick.
Es buena máquina, la tenemos en el taller de Chapucensis y nos va muy bien. Que la disfrutes!!Llegaron hoy. AU $ 129-00 entregado, que es la mitad de precio en este momento desde Edisons Australia
Una máquina sólida y estoy seguro de que me servirá bien.
There is also the same adapter available from Home Depot as in your top left picture Jim. I cut one to the hose size for my shop vac for a Byrnes table saw dust port.You can buy hose port adapters for common tools. They come in variety of sizes and shapes.
View attachment 281043 View attachment 281044 View attachment 281045
View attachment 281047 View attachment 281048 View attachment 281049
View attachment 281050 View attachment 281051 View attachment 281053
Here is the source. Hope it helps
Adaptor Fittings | Dust Collection | Peachtree Woodworking Supply
Peachtree Woodworking Supply is your one stop supply shop for all your woodworking needs.www.ptreeusa.com
Hi Ian,I'd also recommend a supply of GOOD blades. Nothing worse than a blade that dulls quickly or worse yet breaks easily.
Enjoy having your own saw!
Glenn
Congratulations on the new saw, which you will be able to build many models with the sawArrived today. AU$129-00 delivered which is half price at the moment from Edisons Australia
A solid machine and I'm sure it will serve me well.
SUELE Pasar, las cosas se piensan el Alemánia Y SE Hacen en China, ....¡Buena sierra, Ian! Según su plato está elaborado en China pero el nombre sugiere un origen alemán. ¿Es tan?
¡Diviértete mucho con él!
János
[Google] Si. Entendí esto antes de comprar la sierra. Todavía es de muy buena calidad. diseño alemán.SUELE Pasar, las cosas se piensan el Alemánia Y SE Hacen en China, ....
[Google] Gracias. Sí, estoy impresionado con él hasta ahora.Es buena máquina, la tenemos en el taller de Chapucensis y nos va muy bien. Que la disfrutes!!
I would be very interested in hearing how it performs as I'm itching to get a scroll saw myself. Unfortunately their special finishes on the 19th Jan.Arrived today. AU$129-00 delivered which is half price at the moment from Edisons Australia
I've only had time to run some 1/8" strips and cross cuts of Jacaranda through and I can say that I think it's a very solid unit which performs as it should. It comes with one 18 tooth blade and I've ordered some 24 tooth blades to compare the difference in cutting ability. Adjusting the tension is a matter of trial and error and I found if even slightly loose the blade twists and the cut veers off. Just a learning curve and not a fault with the saw. I would recommend it at this current price.I would be very interested in hearing how it performs as I'm itching to get a scroll saw myself. Unfortunately their special finishes on the 19th Jan.
