Sea of Galilee boat - 1:24 scale
United States, Chapel Hill, NC
Excellent model, very nicely done! I have thought of building the Sea of Galilee boat but I still have other obligations blocking the way. I have an article that I copied from the web a long time ago. I have attached it in case it might be useful to others.
Happy modelling.
Steven
  • Sea-of-Galiliee Boat.doc
Lyle,
Do you have a building log for this model?
I got in touch with the maker of the kit and he gave a small information in how he came to build and produce the kit.
I have a building log that I will post as soon as I finish the sail and the rigging.
It is a very interesting model to build.
You did a very good job.
You can find my build log here:
There’s a great book about the discovery and recovery of the boat.
I mentioned it in my build log… worth a read!
Happy modelling.
Steven
Looks familiar… might have been one of the build logs I referenced from time to time during the build.
After further review, this log was the "test" log of the original build. I referenced it quite a lot but there are several differences from the original first build and the current build. Still worth looking at as a reference.
Also, in my build, I took a few liberties in the creation of the boat based on historical possibilities.
Bilbao Vizcaya ESPAÑA
esperando a ver el de barba azul :)
bien construido, y detalles muy logrados.
la verga (palo horizontal que sujeta la vela, no se como se llama allí) me parece un poco gruesa en realidad no suele ser tanto.
la vela cuando hacia este tipo de barcos, solia coserle por todo el contorno un cabo simulando la relinga, y en las esquinas con el hacia los puños de escota, abajo, donde anudaba las escotas, y arriba las empuñaduras que amarraba a la verga superior .
la vela me parece demasiado blanca, yo suelo meterla cuando esta terminada, y antes de colocarla en palos, en un te o cafe diluido para darle "personalidad" :)
en este modelo la vela tiene mucho protagonismo, por ello creo que quedaria bien darle forma de llenado de aire, si le das forma y rocia varias veces con laca del pelo, suele conservar esa forma, pero claro entonces, las escotas tienen que estar tirante , por ejemplo humedeciendolas con cola estando enirantadas.
pero espero lo vean como comentarios constructivos, y en ningún modo criticas, ya que como digo al principio el barco tiene muy buen acabado.
enhorabuena
Miami
Grengraf,
I agreed with you about the details you are mentioning.
I’m glad you mentioned it because there is very little information about this fishing boat.
If you could post pictures of those details will be of great help for me and the others who are planning to build this boat.
enhorabuena
I'm not sure my translator was 100% accurate but I appreciate the comments and criticism.
The build was difficult to find solid information since there is no real information, just speculation based on the time period and other vessel built during that time period.
la foto de detalle del foque de mi barco (es el cutty sark), y abajo como es una vela cuadra.
en aquella epoca no se, pero puños de escota empuñadura y relinga , seguro que tenia para ser funcional
tambien hay cosas que hago que no me gustan, por ejemplo esos clavos- pernos del casco, en realidad, no eran así.
tengo los barcos tras una vitrina de cristal que no se puede abrir facilmente, por eso salen las fotos regular
el ultimo barco de este tipo que hice fue hace unos 30 años, un tiempo que estube impedido en una silla de ruedas.
ahora me pase al lado oscuro, solo hago barcos modernos para astilleros que me piden, por eso abandone un poco la faceta artistica, por la faceta tecnica.
ustedes si que son verdaderos artistas
veo en el traductor de google que algunos términos técnicos navales cambia su significado.
en náutica como saben cada cosa tiene un nombre particular y generalmente cambia entre países, incluso entre regiones.
disculpen si no consigo explicarme bien
The translator comes close enough to understand your points.
I agree that the hull treenails are way oversized... especially for that scale.
Miami
No plans
It does have a super detail instruction manual that the maker includes with the kit on a CD.
Miami
This is what the kit looks like.
A great thing about this kit is that all planks comes already tapered.
The wood is a soft mahogany very easy to bend when planking.
