Hatch Coamings.
As I find it easier to fit the planking around the Hatches, I will make these first.
They are deeper than their lower deck counterparts.
The Coamings are 5.3mm deep and 3.71mm wide.
The Head Ledges are 5.55mmdeep (allowing for the rounding up of the beams) and only 3.18mm wide.
A Rabbet is only cut into the Coamings (1.6x1.6mm) to receive the Gratings.
At the corners are half-lap joints- the Head Ledge being uppermost.The upper part of the cornes will later be rounded.
Above the level of the deck, the outer edges of the Coamings and Head Ledges taper inwards by 1mm (This will be done after the deck is fitted.
Along with Head Ledges the Gratings are rounded up to match the beams.
Some of the Hatch Coamings need modifying to allow for fittings such as Bitt Pins.
Note Main and Aft Hatches have the same width, as do the foreHatch and Ladderway.
The Gratings are divided-2 for the fore and aft hatches: 3 for the main.
I found it easier to make these and fit the “framing” later.
Remember to align all Grating Battens for-aft.
