the Colonial Schooner Hannah in 1/48 [COMPLETED BUILD]
thanks, Sulaire
I forgot to mention a very important detail, I first cut the boards at our friend's site stuglo. He allowed me to use a saw and shares a lot of knowledge about building models. he is an unique man
Hi dear friends :)
Today I focused on the serial production of the parts that make up the frames.
As I updated last Tuesday, I made the boards in the Prooxon Thicknesser DH 40.
The construction started today in calculating the quantity required from each part and I started drawing on the boards the parts from number 1 to number 5.20200807_152150.jpg
Later I started sawing the boards, first at the edges to produce 2.5 cm wide boards.
View attachment 20200807_165735.mp4
Next I sawed the five parts in series. Everything went fine until due to haste (the family dinner was approaching) and inattention I was lightly cut in the finger. Happily the incision was not deep and a basic dressing stopped the bleeding.20200807_184949.jpg20200807_185005.jpg
But it seems to me that in the coming days I will not return to the work of sawing, but do not worry I will return again, that is my pleasure and happiness.
Wishing us all a fun weekend
View attachment 20200807_175809.mp4
Hello dear friends :)
Apparently I was wrong in my ability to curb the passion and enjoyment of building ships model, I went and even finished cutting all the parts into frames b to p. 20200808_155641.jpg
I will update you later about the progress.
wishes all a nice weekend full of pleasures
I’m a little confused by your log! It appears you have several wood species for your frames. I can identify what looks like cherry, maple and perhaps poplar. What will you use for your final frames?
dear Doc
Well done for the sharp and professional distinction Thumbsup
Indeed I practiced the first two frsmes on a cherry, however since the language is rare and expensive I decided to use more available and inexpensive wood.
The cherries and maple boards, I keep to Harmony that I bought her book and maps about three months ago.
It will take me a few more years of learning and specialization before I can tackle it with the required quality.
I dedicate the current model for the purpose of learning and even learning from mistakes.:)
Location determines price. Where I live, cherry and maple, suitable for modeling, is actually fairly cheap. Cherry in “Select & Better” grade is costly, but you don’t need that clear lumber in long lengths to build models! Cherry in #1 Common will yield lots of clear timber in model making lengths (2-3 feet long).
thanks again for your Advice and opinion
Hello my good friends
This weekend I continued in serial production of the layers from which I will make the frames. The pictures best illustrate the slightly Sisyphean process at the end I was able to produce 11 layers of one types.
The process started with sanding the different parts so that they would all be the same and match the drawing.
I then glued the 4 parts that make up the current layer according to the drawing, the wax paper separates the wood from the drawing and also between the weights and the books.
20200815_155648.jpg20200815_162858.jpg20200815_170140.jpg20200815_170749.jpg20200815_174813.jpg20200815_175000.jpg20200815_224902.jpg
Dear Friends
today I continued with the production of the frames, I took care of gluing the two layers according to the drawings.
slowly but surely moving forward to the serial production of the frames, With great enjoyment of the process :D :)20200818_200605.jpg20200818_204933.jpg20200818_210111.jpg20200818_210123.jpg20200818_214209.jpg
