Kit Review The Fram, Motorized Schooner in Scale 1:85, by OcCre
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
As mentioned in the open box review, this kit was selected as the giveaway kit to the member who wins the draw. If you are interested in participating in the draw be sure to leave a comment (post reply). Details at the end of this review.
The Fram
The history
"...I have always believed that the much vaunted "line of retreat" is only a trap for people trying to achieve their goal. Do as I dared: burn the ships behind you, destroy the bridges behind you. Only in this case will you and your companions have no other choice but to go forward. You will have to break through, otherwise you will perish."
Norwegian explorers Fridtjof Nansen
Nansen's ambition was to explore the Arctic farther north than anyone else—to the North Pole, if possible. To do that, he would have to deal with a problem that many sailing on the polar ocean had encountered before him: the freezing ice could crush a ship. Nansen's idea was to build a ship that could survive the pressure, not by pure strength, but because it would be of a shape designed to let the ice push the ship up, so it would "float" on top of the ice. Fram is a three-masted schooner with a total length of 39 metres (127 ft 11 in) and width of 11 metres (36 ft 1 in). The ship is both unusually wide and unusually shallow to better withstand the forces of pressing ice. A disadvantage of this design is that it rolled more than most ships in heavy seas.
Expeditions: Nansen's 1893–1896 Arctic, Sverdrup's 1898–1902 Canadian Arctic islands, Amundsen's 1910–1912 South Pole expedition
The model of Fram built by Colin Archer 1893- 1896​
The Kit
Model Technical Sheet:
Scale: 1/85
Width: 205 mm
Height: 441 mm
Length: 586 mm
Difficulty Level: Medium
Number of pieces: 1974
Approximate build time: 480 hours
Ref: 12011
The Fram, a model kit by OcCre offers the opportunity to recreate this iconic piece of polar exploration. The design of this model is close to the original, and the kit provides all the necessary elements, it includes the most specific naval details you can imagine along with the sails set and basic stand. As with most of OcCre's kits, the Fram is packaged into a standard-type OcCre box with a cut-out to display the nice fittings box that is a feature of these kits. A color-printed product label is affixed to the top of the kit's box cover, and the entire box itself is protected in a shrink film.
The wood
Lifting the top of the box reveals the packaging of the lower box where you can see the kit's contents through multiple cut-outs. The box then splits open to access the various kit's parts. One of the boxes half exposed the milling wood bundles held together gently with elastic bands. One of the bundles is used for the first layer of hull planking. Its creamy-looking timber, makes me think it is a lime wood. The wood looks without split edges and the strips are consistent in size.
The next bundle consists of strips of various shapes, sizes, and species. You can see some Tanganyika for the second layer of hull planking. There is more Lime wood supplied for the planking of the deck.
The last bundle consists of both dowels and strips, as well as brass wire.
Other timbers: Wood, MDF, and Plywood.
The remaining timber parts have been packaged using heat-shrink clear plastic to avoid moisture coming into the bundle. Once you have removed the plastic wrap, you can see the remaining timber including the MDF false keel, plywood bulkheads, and plywood false desk as well as the MDF lifeboat formers.
Being an MDF, the falskeel doesn't show any warp., it is perfectly straight. It is my observation, that all laser cuts. On all boards, are of excellent quality: very thin and no burns! Another MDF sheet deal with parts to assemble various small boats and contains jigs, false keels and bulkheads.
The plywood plates consist of the bulkheads, bow formers, masts stands, falsedeck pasrts, and parts for the basic stand. While the bulkheads show no warps, the falsedeck has indeed a warp. However, it is not a problem as it will be glued on top of the bulkheads (the hull formers).
600_5109.pngthe other side just show the nice lasercut line without burns.
The last three sheets are walnut keel and stem/stern parts, and some cream-like wood for boats and ships gunwales, No warps on either of the sheets.
Not too many kit manufacturers include the sails in their kits. However, OcCre included a full set of sewing sails for Fram. I can observe some fuzziness on the edges, however, once you attach your own bolt rope it should hide it.
will continue on the next post (25 images limit)
... continue from the next page
The cotton rigging lovers will be delighted to know, that the kit provides plenty of ropes. Ten (5 tan and 5 dark brown) spools of various thicknesses were provided in the kit. The size of each thread can be easily identified. The thread shows no apparent fuzz (only macro).
The PE parts and Fittings
There are two brass photoetched frets supplied in this kit. They contained parts for chainwales, multiple winches, etc. The larger sheet comes in the envelope along with rigging spools and has some noticeable bents.
The fittings and other small parts have been packaged by OcCre in a clear box. This is the signature of Occre and can be seen on all their kits. While it is a great way of keeping fittings organized, the box can be used for your parts after the assembly is finished.
The metal parts are made from Zamak (a zinc alloy) and the casts are as clear as they can be. There are some slight seams found on most parts, you will need to file those so the parts look nice. Among the Zamak parts various sizes of vents, and winch gears, the steering wheel, binnacle, water pump parts, and anchors. Here are also davits for the boats, etc.
Among other parts from different compartments, you can find rigging blocks and belaying pins. I am not thrilled with the quality of either of those. The holes seem to be drilled randomly and in some blocks, the hole didn't go all the way through. Here you see the parrel beads, deadeyes, mast hoops, anchor chains, printed flags, and the the ship's nameplate.
Here we can see the various pintles and gudgeons, chain for the anchor.
... parts for gratings, nameplate, and printed flag
Also, there are various shapes, thicknesses, and diameters of brass material to fabricate some required parts.
Assembly Manual and other documents
I cannot imagine any kit without an assembly instruction manual. Seems like OcCre paying attention to a good manual, and Fram is no exception. There are sheets with detailed masting drawings, along with a sheet of parts identification. Below are some sample images to get an idea. BTW, they are written in 5 different languages!!!
For the second set of sheets, the step-by-step series of color photos you will follow through the build. This is a standard way for OcCre's assembly manual and should lead you to a successful build. Here are some sample pages.
continue on the next post due to 25 images post limits.
... continue from the last post
The Model (images courtesy of OcCre)
OcCre manual
Conclusion
The Fram kit by OcCre certainly has a lot of good quality material including MDF falsekeel and zinc-based metal parts. The rigging threads galore and sewn sails will certainly please anyone who loves cotton ropes to rig their models. The color photo step-by-step instructions seem very simple to follow, as usual for OcCre's standard manual. Another very nice model kit from OcCre.
I think it is a good kit. What about you? What do you think?
As mentioned earlier, SOS has one Fram kit from OcCre to give away. There are no requirements other than a willingness to build this kit and hopefully show in the build log on SOS (but not necessary). And with a little bit of luck, someone can acquire this kit for free. For the following few weeks, we will collect members who would like to participate in a draw. Once we collect all members, we will take the draw and the program (below) will choose the winner. The winner will have to pay the postage only (no international please). If you have any questions, please PM me.
Please reply to this post saying that you would like to participate in the draw. We officially collecting members starting today 2/11/2025 and will close collection on 2/24/2025 with a draw date of 2/25/2025 so if you would like to take the chance, please use your time wisely ;) Good luck!!!
This is the program we will use to choose the winner.
Members participating in the draw: 51 (total)
@bowwild
@Senorbob
@Bobby K.
@RegG
@Mwentling
@swampdweller126
@Norway
@Bill-R
@steven
@gene438
@RussF
@Sindre
@Botrix
@makow
@EspenT
@Genesis
@Noël Luc
@Bob Elliot
@Fletch Dog
@Justin tillman
@Rebelreck
@Jim B
@Jstoecker
@Drobbs
@darnold
@Doc Patrick
@bigdoc2000
@JimMc
@lhend
@Robert707
@oorsouw53
@Coppens
@neilm
@Jorge Escudero
@Asheshouse
@skstiel
@Spf350
@seawhich1
@mick
@adrianoart
@Steviedean
@jcurtis55
@davghol
@mpampis
@omaquinista
@Magic Mike
@Omega
@mxs
@smonsma
@cpieczynski
@anllna
I have never made an OcCre model before, it would be fun to win one. Please put my name in thanks.
Bobbyk
Hi Jim, what do you think the shipping costs to Norway will be?
I have grown up with stories about this ship and her historical exploits.
The reason I am expressing my interest is that my health is very poor now.
I have been diagnosed with impaired heart function and a large prolapse of the main artery.
I came home from hospital on Saturday after an operation/stent inside the main artery.
Conclusion - it will be a long time before I can continue with my machines and projects since I simply do not have the strength for such work in the near future.
I have built some model kits before so I know that it does not require too many tools to build this one, and it does not require a very large workspace either.
This could suit me now in these bad times with poor health and little freedom of movement.
And, Fram is a ship built in Norway, the country where I live and grew up.
I have also been on board the ship at FRAM MUSEUM.
I usually don't like to complain about my health and problems
but now I do.
Postage means nothing if it's not higher than the price of the kit here in Norway
Greetings Knut-
I have completed 3 previous Occre models and have never been disappointed. The kits are always well made and the instructions are the best.
Count me in!!!!
Sure, I will include all the members wishing to participate in the draw. But...I am wondering if anyone has read the review. :cool:
I did, and when I saw the person holding three bundles of wood I entered right after. Lol
Bobbyk
