The Schooner Bluenose Plans discrepancies - which is most accurate?
I am preparing to build a model of the 1921 Canadian Schooner from scratch and looking for a set of plans faithful to the original. But during my research I have found some irreconcilable discrepancies. I am looking for some help resolving them.
I am using the measured drawings by L. B. Jenson from his wonderful “Bluenose II – The saga of the Great Fishing Schooners” as my gold standard. This appears to be the most reliable source as the drawings were taken from the original carved wooden half-hull model and actual measurements of the Bluenose II. The Bluenose II is claimed to be “an exact and faithful reproduction of the original“.
The following are quotes from L. B. Jenson’s “Bluenose II – The Saga”: “The only departures from the first Bluenose are in the accommodations & stowage and in the addition of modern navigation devices now required for sea-going certification.” and, “Mr. Fred Rhuland, one of the original builders of Bluenose II, very kindly made the original half-hull model of Bluenose available to me to copy. This of course forms the basis of the hull drawings and, insofar as possible for me to determine, checks out precisely with the actual hull of Bluenose II”.
Lathan B. Jenson’s “Bluenose II – The saga of the Great Fishing Schooners” was first published in 1994, but is an adaptation and expansion of his portfolio “Bluenose II, The Last of the Tall Schooners”.
In addition to the L. B. Jenson measured drawings I have been looking at three other model ship plan sets. The first was drafted by H. W. Porter in 1940. The second was drafted by Phillip I. Eisnor in 1988, and lastly plans offered by Model Expo, Bluenose MS2130. The Model Expo plans are the ones in the Model Shipways 1:64 scale kit. I do not know the providence of the Model Shipways plans, but am interested to learn.
Now before I launch into my findings, I want to apologize in advance of any perceived slights that readers may infer from my word choice or method of presentation. Whenever two opposing views are presented, there is a possibility of offense taken on one side or the other. I do not mean any disrespect and the opinions and interpretations here are wholly my own. Secondly, I will be presenting pictures and statements that I have found in the public domain and will attempt to give credit wherever possible. If someone has an issue with my findings, or feels I am violating some copyright law, please let me know and I will remove the offending artifact. Also, I will be presenting pictures of plans, but will be using blurred versions that are already viewable elsewhere for advertising purposes. None of my posting of plans could be used by anyone to build a model.
When looking at all of the collected research materials, I am most concerned with the discrepancies related to the shape of the ship’s hull. Particularly differences in the aft end, the shape of the transom, the curve of the bow and the shape of the rudder. L. B Jenson’s drawing show a Bluenose with a very sleek, streamline aft, ending in a small roundish transom. Whereas, the other three sets of plans show a standard Gloucester Schooner aft end, not so tapered, squarer when viewed from above with a wider oval transom. Also, the rudder shapes are quite different. L. B. Jenson’s drawing shows the rudder with its center of area higher than shown in any of the plan sets. The bow of the Bluenose, according to L. B. Jenson, corroborated with pictures and videos of the original Bluenose, has a profile with a smooth curve with a constant decreasing rate of curvature fore to aft. Whereas a couple of the other plans show an abrupt change in the rate of curve at the bow commonly seen in other schooners.
Let us start at the aft. Compare the top views of the aft end of the Bluenose focusing on the narrowing of the shear and the shape of the transom:
The original Bluenose from L. B. Jenson’s drawings:
From H. W. Porter’s 1940 plans, the rear is squarer and wider:
Phillip Eisnor’s plans similarly has a square aft:
Found here: http://www.modelshipbuilder.com/page.php?26
And the Model Expo plans aft end:
The squarer aft in the Model Shipways kit:
The last two pictures are from:
Comparing the transoms:
from L. B. Jenson’s drawings, the transom is almost heart shaped when viewed from the rear:
Whereas the transom from Phillip Eisnor’s plans is wider and more oval:
Now, the rudder:
L. B. Jenson’s drawing of the rudder:
From H. W. Porter’s 1940 plans:
Phillip Esinor’s rudder:
Model Shipways rudder:
The above is again from Suburbanshipbuilder.
I am not so concerned with the different shaped rudders. They are just indicative of all of the plan’s deviations from the original, that is, if you accept L. B. Jenson as the gold standard.
Now let us turn our attention to the bow.
In Phillip Eisnor’s plans and Model Shipways plans there is what I call a “knee” in the curvature of the bow. This is a section where the rate of curve moving from the bowsprit down the keel, abruptly increases, then decreases.
Below is another example of a schooner, the “Henery W. Adams” that has the “Knee” in the curve of the bow. It is like there is an almost vertical cutwater that then curves into the keel at the “Knee”.
Below is the model shipways kit, also with this “Knee”:
Interestingly, the plan set that comes the closest to L. B. Jenson’s drawings is the one from H. W. Porter. There is no “knee”, but the bow looks more swept back than the original Bluenose:
Below is the drawing from L. B. Jenson of the Bluenose bow. The curve starts at the bowsprit and as it moves down the keel the rate of curve decrease, that is it flattens out, without the abrupt change in direction of the rate of curvature. There is no “Knee”.
I have found photos and the video below that corroborate the smooth continuous curvature of the Bluenose bow.
And:
So, there you have it. Please share your views on the evidence I have presented. I may end up purchasing a set of plans and then modify them to more closely resemble J. B. Jenson’s drawings. Given the money and time invested in building a model ship, one wants it to represent the actual ship as closely as possible.
I do not know anything about sailing ship design, but I wonder if any of these differences between the Bluenose hull shape and other typical schooner hull shapes, resulted in her superior speed and, some say, undefeated racing record.
Now, the rudder:
And:
Hallo @Trunnels ,
a warm welcome here on on board of our forum.
Very interesting information you put already together.
Sorry, I am not a specialist for this type of vessels, but I am sure, that there are some of our members can assist you with answers and information ......
Enjoy and good luck - Hope to see much more of your work, maybe in a building log of your project...
Hi Trunnels,
A must go to page for anyone building a Bluenose is novascotia.ca
Look at the historic images in the "Marine Survey of Bluenose".
The images show all the areas you are interested in, they are very detailed and you can scroll and zoom.
Good luck with your build. Stay safe and well.
Hi welcome to SOS, imho there is no real right or wrong way in trying to decide exactly how the bluenose can be built the most accurately. You have to decide in the end what after much research is going to make you happy. LB Jenson was born the year Bluenose was launched. William Roué's original plans for the hull do not exist unfortunately. But in Ottawa Canada the government Museum of Natural History has purchased the William Roué collection and has a Bluenose exhibit slated for end of June. Link Here! I am hoping they will put this online.
It is worth searching for Canadian government records for the Bluenose and not just the Nova Scotia archives. I have seen a Roue plan of the interior but have been unable to find said since. I believe it was at the National Gallery... Good luck will look forward to your build. Regards, Robin aka Nova ~
PS: Nova Scotia archives has great pictures of the transom as you are probably aware...
The video you posted seems to favor a smooth curved bow (no knee) and a more elongated oval transom rather than heart shaped. I watched it several times and you get glimpses of both the bow and the transom. Let us know what you decide...
Hi Trunnels. I have that Portfolio, The last of the Tall Schooners by L. B. Jenson and wiil see if I can be of any help to you. Seems I got this about 30 years ago with the intent of building Bluenose and just been sitting on the shelf waiting for me to build her but seems I just don't have time for her. Good luck and will see what I can come up with. Gary
Trunnels; I was lucky for I purchased my copy of the original drawings at the cost of the printing about 20 years ago from the" MARITIME MUSEUM OF THE ATLANTIC, 1675 LOWER WATER STREET,HALIFAX, N.S. CANADA,B3J 1Z3 and I also found a book called " Bluenose ll " Saga of the Great Fishing Schooners, Measured Drawings By L.B.Jenson, Nimbus publishing ISBN 1-55109-063-5. The whole book is hand written and full of line drawings of sailors at work individual parts drawings interior drawings etc. too numourus to mention. Probably could be purchased from somebody like alibris @ alibris.com and are usually in good shape as i have purchased many of my nautical books from them at reasonable prices.
Wow, thanks everyone. lots of good links and insight. At this point I am looking for any pictures of the original Bluenose transom. I'll take anything, but preferably a direct view at the aft end. I still am conflicted about the transom and I tend to agree with Jim Daniels that the pictures I have seen favor an elongated oval shape.
If you look at the link posted in Nova Storm post you will see the last two lines on the right hand side of the page read" Copy right 1922 A. D.
W. J. Roue "
This is the drawing being referenced. The shape of the bow is confirmed with no "knee", the transom is harder to discern.
maybe the reason there isn't a plan of her water lines is because they used a carved half hull of her and took a table of offsets for building the real bluenose. Just a ideal guys.Are there any as built plans of her? or it wasn't untill blue nose two was done before they had a set. Just a thought guys. Maybe am not reading every thing right. Gary
You are correct Gary. I quote L. B. Jenson: "Blueprints do not exist for most of the wooden vessels which were built in Nova Scotia. Instead the lines and measurements required for construction were dericved from carved wooden half models, usuallyon a scale of 1/4 or 1/2 inch to the foot. Experience determine the shape of the hull." L. B. Jensen was fortunate enough to be able to take measurements from the original carved wooden half model of the Bluenose. Of course, that does not gaurntee that those lines were perfectly translated when constructing the original ship. Today photographs are the only true record.
There is a facinating set of videos of the building of the Bluenose II, here is an example:
drawing for the hull lines of Bluenose, signed by William Roue are the originals from the designer himself and are in the Provincial Archives of Nova Scotia
a number of drawings and ship model kits of Bluenose sold today, in comparison with the original hull lines drawings of her designer, William Roue, are not as accurate as they claimed to be.
Philips drawings of the Schooner "Bluenose" may be perhaps the most accurate representation of the "Bluenose" as she was in 1921 when she was launched and ready for the fishing grounds (entrants of the IFTC were required to be working vessels). Philips spent many years in researching this project. Much of his time was spent in the Nova Scotia archives and talking with people in the Lunenburg area who sailed on the "Bluenose" along with some of the shipbuilders who were responsible for building her.
Philip's plans are available and copyright protected for personal use only.
As far as I can see when I compare Phillip Eisnor's plans to the plans which I received Stamped Copy right 1922 AD, which I assume are the closest to the 1921 build, Appear to be identical and as you know you can pull down the same plans as you would get from the maritime museum in Halifax what more do you need?
I would be looking closely at Phillip Eisnor's plans for the hull lines. From Nova Scotia Phillip put in a lot of time and research into getting this aspect as close to right as one probably could.
It may also be important to remember that there was a change made by Walters as I recall it was right at the time of construction of the hull which added an additional 18 or 20" to I believe it was the height of the stern. I'm trying to grab all this from memory but you can research it.
Model Shipways/Eric Ronnenburg mentions this also in the kit manual, " Model Shipways developed the Bluenose kit in 1996. The model is based on several sources. In 1961,John R. Stevens prepared plans for the Fisheries Museum of the Atlantic in Lunenburg, Nova Scotia. He modified Roué’s original hull lines to include more forward sheer. This change, made during the construction of Bluenose, gave the lower deck more headroom. Stevens’ lines were checked against a similar set prepared by the late Howard Chapelle and now in the Smithsonian Institution. Sail plan and spar dimensions are based on Roué’s 1922 sail plan and those taken from the ship during her racing career."
I believe other changes were made as well as mentioned on Wiki, Roué made revisions...
Hi Trunnels,
I am a member of the ship modeller's guild in Lunenburg so I visit there often during the summer and have gotten to know a number of people from there quite well. These modellers seem to accept the drawings of L. B. Jenson and I have seen a coy of his larger plans where all fittings are clearly shown in fourteen plates. It is generally accepted that these plans are the closest to the original and that some changes were made in the building of Bluenose II. I suspect that some minor changes may have been made to the most recent re-construction of the Bluenose II.
