To victory and beyond ...
Next the barrels were continued. The number of hoops is interesting here. As an average layman, one would assume 4. However, Nelson's brandy leaguer shows a completely different number, and the double hoops are particularly interesting. I found several references to the fact that larger barrels have a double hoop at the top. So once again, nothing with once programming 1 barrel and scaling it to all sizes ;-)
Each barrel format is unique, and I have attempted to develop a reasonably plausible number of hoops. After all, a 675-litre Leaguer weighs over 0.8 modern tonnes, so there is a considerable amount of self-weight to bear, especially during transport when dynamic forces are added.
The result was a nice family picture:
The 1.55-metre-high, 104-cm-diameter tun is the largest in the series, but I have not yet come across it in a maritime context, probably because it is too unwieldy. The smallest here is the firkin, with a capacity of 9 gallons, a height of 56 cm and a diameter of 43 cm. The powder keg on the Invincible has almost identical dimensions and, in my opinion, is a firkin with special tyres.
The picture clearly shows that the size range of the different sizes could be reasonably accurate. Using this overview picture, I was able to compare the shapes of the different sizes.
And here are the next samples of the barrels. The differentiation between the various number of hoops results in a pleasant visual impression for eye of the beholder ;-)
The selected sizes are, in descending order, leaguer, puncheon and hogshead, as these are always mentioned when stowing the hold, plus the kilderkin as it is a basic measure and the smaller firkin for boats and as the probable size of powder barrels.
The stacking in the boats is based on historical data, so special launches for first and second rates could hold 14 to 16 leaguers, which is a mere 8 to 10 modern tonnes in weight. I dare to doubt how much freeboard was left, but perhaps there wasn't as much heavy stuff in there as liquids ...
XXXDAn
And we continued with the lugger-rigged version of the large launch.
First came the masts. I took the measurements from W. E. May's summary, but they also correspond fairly closely to the French measurements. The strength of the lugger rig is its simplicity. Insert the pre-rigged mast, hook in the pairs of backstays on both sides with the standing end, hook the tackles in the middle, and belay the free end. The halyard of the sail is already sheared through in the masthead, so the sail is immediately hoisted, the tack, sheet and brail are secured, and off you go.
In my scrap box, I charmingly found a sample from my sandwich sail tests from 2017 – yes, I actually keep such things for that long – and the sizes I need fit quite well, even avoiding the messy areas. I developed the material back then to combine the advantages of fabric as an elastic material and paper for a more true-to-scale surface. Thin strips of restoration repair paper are ironed onto both sides of a layer of silk to create a sandwich that resembles closely the visual properties of the sails. It is also unbeatable for folding and stowing. However, at the time, I did not yet have a model that was ready for me to use it on ...
I took the angles from Steel's drawings, but I had to mark the radius at the bottom – one of the differences to French sails – with a pen and thread, as the radius is larger than my templates.
I shortened the furled sails by approx. 25%, i.e. below the lower reefing band, which I had also omitted for this purpose.
The surrounding leech was glued on and the eyes for the brails were added.
If necessary, I'll even clamp a sail in a vice ;-)
And then it was time to fold and fiddle around.
And then it was adjusted to fit the storage space.
Together with the masts in place looks quite cheerful and full. Two barrels have also found their way there. Who can find them?
It's great to finally be able to use the sails developed eight years ago in a model myself. Some modeling friends have already impressively demonstrated their potential. Thank them for that.
And I'm already testing out the next crazy ideas for my boat collection...
XXXDAn
Daniel,
This looks really beautiful. It's amazing how much time you put into it. I really like it.
Cheers, Günther! Ship-1
Ok, let's talk about something we guys know more about: guns.
Or at least we think we do.
In the past, model guns were mostly rotational pieces, and only larger-scale models were retrofitted with details such as ignition pans and coats of arms. These were custom-made or complex castings. With the printing the excuse of the effort involved no longer applies. That's why I finally finished the new guns for my Victory.
And here starts a new point of discussion about how to present the guns. Not saying that the classical we usually show is wrong, but as an opener for mind and possibilities.
The version we usually show is with an exposed touch hole and without a tompion is simply how we know these things from museums and recovered from wrecks.
But in real seafaring life this appearance was probably rather rare, it was probably mostly different:
There are enough orders, records and wreck finds that describe the guns as most of the times ‘loaded’ during the period of 1800 and before. This also means that the powder charge stored inside the barrel had to be protected from water and moisture. For this purpose, tompions, simple wooden turned parts, were used as plugs at the front. They can be seen in many paintings, mostly white.
The sensitive touch hole also had to be protected. Lead covers were used for this purpose, which protected the touch hole of dirt and, if the gun was equipped with one, the gunlock, and above all protected the hole against fire and sparks.
When the gun was made ready for battle, the tompion was removed as late as possible and the cover of the touch hole was removed also only shortly before the shot was to be fired.
Thus, in real life, there were mainly the following 2 conditions:
- Stowed, lashed down, run out with cover over the touch hole or gunlock and with tompion
- Shortly before firing, without cover over the touch hole or gunlock and without tompion
Here we have the triad of touch hole, gunlock and cover in comparison:
And here are the five gun sizes required for the Victory:
32-pounder medium lower battery deck, 24-pounder medium middle battery deck, 12-pounder long upper battery deck, 12-pounder medium aft, 12-pounder short quarterdeck.
The classic ‘pure’ representation with open touch hole
With gun lock. It is worth considering that the tompion could also be set if the enemy is not yet within firing range.
And with cover and tompion.
I adapted the colour of the lead covers to the artefacts from Thorsminde. The same applies to the fastening holes. This also results in the rear fastening via the ring, as all other types of fastening would slip off.
The colours of the tompions – natural wood, white, red – are taken from the artefacts and paintings and should, of course, be uniform on the model. The wood-coloured ones were probably the most common, as the tompions were carried as prefabricated spindles in sets of about a dozen and simply sawed off as needed. I doubt that they were painted every time.
Side discussion:
Also this involves in my humble opinion the presentation of the tackles. If stowed it is clear that those have to be properly set to hold the gun, plenty of drawings show this. If ran out but gun secured (Touch hole and muzzle protected) those tackles should be secured too but probably not laying on deck. If ran out for "clear for action“ (touchhole and possibly muzzle protected) the tackles should be open, but secured on the carriage, the free ends in a way that it wont become knotted. And just straight before the shot: no muzzle, gunlock or vent hole open and the tackles be held by the crew.
Is there any place for the nice spirals we like to show, especially with an tackle not made fast? Try this in real life and the guns will run amok at the first wave ...
HTo round the theme up, here are two scale pictures of the barrels above :-)
Enjoy :-)
XXXDAn
You never stop learning, you never stop learning.
For 10 years now, I've been showing these gunlocks sitting centrally above the tube's ignition pan, when druxey in MSW points out that this isn't the case, that they're off-centre. So I took another close look at the few pictures on the internet, and sure enough.
So, the gunlock has been moved to the correct position, and I hope it's now a little closer to the original :-)
Flanged to the starboard side of the ignition pan of the barrel, the retaining bolt(s) pass horizontally through it, so the barrel itself does not need to be weakened. The pan of the lock protrudes above the pan of the barrel.
There were also corresponding changes to the lead cover, with the cap moving slightly off-centre.
Accordingly, there are again three variants of the representation, with cover, flintlock and open ignition pan.
The flintlock shows that the printer is at its limit, and when the metallic paint is added, it looks a bit washed out in close-up. Here is the lock with just primer, which adheres better.
And here is the dimensions-based visualisation.
Have fun :-)
XXXDAn
Awesome as usual, Dan. Time to do another printing batch. Did you post how you made the sails? Will dig through the files and check. At least I have a ballpark date, 2017! Will let you know if I do not find it. Regards, Pete
Time to continue with the big launch.
The masts have been redesigned, with details taken from Steel.
I keep noticing that thin printed parts such as oars and masts warp after painting. See the upper half of the picture.
After a quick dip in hot water, they are straight again, see bottom half :-) I simplified the rigging of the launch and combined various sources. As with the Hermione boats, the eye bolts were no longer attached to the top of the gunwale but underneath on the frames. It looks much clearer. Here is the first dummy rig with the newly positioned attachment points.
Once rigged, it looks like this. I actually wanted to work without stays, but due to the stubborn rigging, this is hardly possible without curvature. The mainstay should then of course lead to the foot of the foremast.
Here are the attachment points in detail. The running end is wrapped around a cleat, but not yet stowed.
And the sails are also waiting to be processed :-)
XXXDAn
Thank you Rebus!
As I have wrecked the sails, there is a forced break at this point to ‘reweave’ them. Since my day-to-day business leaves little time for this, it is taking longer than expected.
Therefore, I am continuing with a rowed version as an interim action to build. According to the armament list, the Victory had a 24-pounder carronade for the big launch, for landing operations and similar tasks. It is time to continue with this little vignette. To this end, I have acquired a 24-pounder from my Constitution model, removed the first thwart, reinforced the second one, and already have a passable support. I have also added the swivel guns from the fighting tops of the my Constitution.
First, I checked the length of the breech rope.
The green underlay is good for rigging the small blocks, as you can push two needles into it as holding points. The blocks themselves were slotted into the vice as already described.
And then it was finished :-)
The tools for the carronade are already included, shortened in comparison to the other guns. The cannonballs are stowed deep in the boat in the rack. All that's missing are the small salt boxes for the powder cartridges and a toolbox.
Enjoy, Daniel
And I am always delighted by the fine structures that are now possible in printing. Once again, parts whose diameter is half as wide as my papillary ridges, these are some of the finest parts of my products :-)
XXXDAn
I was in model-building deprivation, with no time to do anything and not even to document what I had already built.
The version of the Launch with sails has to be stored in the back for now, as martens have damaged it by chewing on the sails ...
That's why I continued with the version equipped with a davit for anchoring and fishing. Here some pictures last stage.
First, there was the question of where to put the cable that had been hauled up. Instinctively, I had stowed it in the bow during the first test.
But in order to attach a pulley to the capstan that can only be attached forwards to the stem and the cable accordingly had to go to the rear. So I decided to store it in the middle of the boat, which is also better balanced, and you can see that this is a good solution.
But first, a little bit of small stuff, which also makes a difference ;-)
The pulleys are pre-assembled; this one should hang loosely, so I shaped it with wallpaper glue.
The grapnel anchor and ladles have also arrived.
To tie in the anchor rope, I clamped a pair of tweezers in my vice.
And then I built a nice bunch with the rest of the rope.
And here it is the small menagerie.
And now it got pleasantly exciting, but see for yourself...
While two lads secure the pulley, the capstan bar is being changed on the other side. The lieutenant keeps a watchful eye on the whole process, while one man checks to see if anything is happening at the back end at the cable. In the middle, one man holds the cable taut and clears it neatly. That setup certainly wouldn't have worked with the rope at the front in the bow, as crowded as it already is there.
Cheers, Daniel
Thanks Eberhard and Marijn: Psssst ;-)
Cheers, Daniel
Incredible work that is very impressive.
The details of your Victory such as the proper gun pattern and launch details should be an inspiration to others. Well done.
Captain Dafi, personal logbook, addendum:
Recently, it was time once again for public tinkering at the game fair in Stuttgart. I had brought quite a bit of material with me again.
A little reminder of Èvian :-)
And my Soleil in full sun—simply BEAUTIFUL!
One of my topics was the comparison between the parts that come from the kit and what you can make from them. Here is a comparison of the two upper decks.
And as usual, there was plenty of delicacies to enjoy: pumpkin-sweet-potato-carrot-potato-ginger-soup special recipe dafi — yum!
Enjoy, Daniel
Before heading to the trade show, things were naturally crazy for me – splinters were flying once again.
One of the things I wanted to show was a comparison between the original kit parts and what you can actually make out of them. To do this, the decks had to be prepared.
First, the old gratings had to be removed. Then the good parts of the deck were protected with gaffer tape and the old coamings were sanded down with a coarse file ...
... and the remains were removed with a blade ...
... or helped along with a fine file.
For the finishing touches, I sawed a batten to the right width and covered it with sandpaper, which allowed me to achieve a nice even surface.
Since the new coamings are also supposed to cover the thickness of the decks, I had to cut larger the openings of the companionways a little. A red pencil line serves as a mark.
This was trickier on the upper deck, as the deck is not divided in half. But here too, I first had to cut out the grating ...
... cut out the coamings with the flat blade and finish them in the same way as the lower deck.
For the wide openings at the rear with the thicker coamings, I made a 45° relief cut with the scalpel, which meant there was less material to remove horizontally.
This made it much easier to work with the blade.
And then again, enlarging the section by the width of a pencil.
For this exhibit, I deliberately chose not to use a purchased wooden deck or one built one like on the other model, but to experiment with what could be achieved with paint.
Now it was getting exciting ...
Awesome! another detailed decking tutorial.
There has to be a Christmas song in here somewhere, "Deck the boats with shades of glory" or something like that......
Next, I had to come to terms with the not *quite* correct planking pattern. A few beers later, I was fine ...
Then I realised that the plank gaps were much too wide and would be far too prominent for my liking when filled with paint or wash. So I came up with the following plan: I sprayed the deck black ...
... and then scraped off with a blade so that the black paint remained in the depths like preshading. As always with my best plans, it ended up being a big mess.
Then I tried out different shades of brown, both solvent-based, acrylic and water-based, in various opacities. It resulted in a pretty patchwork.
The forecastle in particular was quite colourful ...
...which is why grey tones were used on the gangway.
But what can I say, I really didn't have such a grimy deck in mind. So I sprayed it again and stripped it off again.
In the meantime, I had remembered the other moulded parts, especially the gratings, which I had tuned to wood. That was the specification it had to match. And even though there are usually no major colour differences in the wood on original decks, except for traces of moisture, preshading with black prevents it from looking too much like a painted steel deck. You just have to throw your imagination a few little treats now and then to keep it happy. It was just a matter of finding the right balance. So I applied three glazed coats of paint until the black was only very faintly visible.
Interestingly, the plastic of the upper deck was a light beige, while the lower deck was reddish brown. This was easily remedied by applying a grey glaze under the brown glazes.
This technique also brings the area under the forecastle, which has no plank engraving, to life so well that engraving was not necessary and simple pencil strokes can substitude the engraving. I think that, given the limited visibility of this area, this is a good effort-appearance ratio.
So, quickly in with the printed parts...
...and take some beauty shots.
Oups, and I forgot to tell you that before the planned mess, we first had to test fit the new parts.
Non-existent openings in the admiral's quarters were marked...
... cut out ...
... and adjusted to the bulkheads.
The coamings and gratings were also adapted to their openings, or vice versa.
And at some point, the upper battery deck was completely covered with coamings.
The same procedure was followed for the forecastle and aft deck.
The coamings are not as high here, as there were open decks underneath.
In the area of the main mast, the gratings can be taken out, as there are some ropes leading to the bits in the deck below. This makes it easier to belay them.
I also installed those bits and, as a little treat, a new hand pump was also installed there.
Then the coamings were given their colour. The gratings were then masked off and painted light brown, then inked very thinly with black ink and brushed with white.
And then there was the slave labour: gluing in the cannonballs...
...and securing them on the underside with thin-flow superglue.
Finally, I doped the railing with the net holders...
... and add some thickness to the gangway with white Evergreen on the underside ...
... and this part of the task is finished.
