I am working on a Calder craft Victory and struggling with the top sail lifts. They start on the mast, out to the block on the end of the spar, then back through a block in the upper shroud. Now comes the problem, how does it get down to the lower shroud cleat that is labeled as the belaying point. The directions say it goes back out of the fighting top, (okay) so out of the upper shroud, then back through the lower shroud to get to the shroud cleat, or is the shroud cleat actually on the OUTSIDE of the lower shroud???
