Triton Poseidon Cross Section POF Scale 1:48
A
Aussie048
Guest
#1
I purchased Triton Cross section sometime ago online that recently arrived.
I decided that I needed a break from planking on a large ship like my USS Constitution and did not want to rush it. As I had seen another build log of Halifax I decide that was a big step but with the Triton Cross Section to learn the process of building a POF.
I have started building the building box for the Triton and started looking at the manual to get a feel of the build procedure.
The cannons in the kit are the best I have seen in a kit, but you will have to wait to see them.
Cheers
A
Aussie048
Guest
#3
Hi Brian
It is giving me a good giving an insight into POF. I have dry fattened frame 1 And B so I could check out the jig. To see if it need a bit more rubbings down. I Think it does. It's a bit hard to start of with as the instructions are Chinese
Cheers.
Geoff
Brian077
Well-Known Member
Melbourne Australia
#4
Don't worry about the instructions mate. Theres plenty of build logs you can look at and you just need the drawings and numbered parts anyway.
I bought some of these rib clamps from the internet which were quite were cheap for holding things in place until the glue sets. TB21NF9XVXXXXa0XpXXXXXXXXXX_!!22670794.jpg_600x600.jpg
A
Aussie048
Guest
#6
That is a nice looking jig Brian.
Hi John
Yes it is a bit different to POB jobs. I am enjoying it
Cheers
Geoff
A
Aussie048
Guest
#7
I have been quite busy cutting out parts for frames. I have 3 frame glues up worked out there was some errors in the parts list, which slowed me up a bit but when a part has cutout in it and on of the cutouts is going straight into the other frame where a gun port was to go,even I could work out there was a problem. So in total I have identified 4 errors. I have one frames to glue up and currently cutting out frames 5 out of 9.
I make no apologies for my work bench being a disgrace. That is just the way Model Ship Building can be at times.
Cheers
zoly99sask
Well-Known Member
Administrative
Blandford Group Build
#9
Good start Geoff,can't wait to see more.
A
Aussie048
Guest
#10
Thank Brian and Zoly
I decide I will dry fit all the parts give them a rough sand for all the frames then give then a fine sand before gluing together.
Might take a bit longer but who is in a hurry.
Cheers
Geoff
A
Aussie048
Guest
#11
I have been busy cutting out the parts for the frames still.
Currently I am working on frame 8. Most of the frames have had been sanded with a course sandpaper and are just dry fitted. I will dissemble them and sand them with a fine grade paper prior to gluing and pinning, I have not place the false keel in the jig as yet as it will need some work done on it. I will need to stain the frames as the colours of the different timbers varies quite a bit. As yet I have not identied the type of timber used in the frames.
Cheers
Mike41
Well-Known Member
#12
Hi Geoff,
You are off to a good start. Cross sections are an excellent way to start plank on frame modeling.
Mike
A
Aussie048
Guest
#13
Thank Mike
I think it is the best way to do a POF, something fairly small in a cross section.
Cheers
Geoff
A
Aussie048
Guest
#14
There has bee a fair amount of sanding involved so far. I have glued a few of the frames and the rest are dry fitted.
The box is full with the 9 frames.
Cheers
lauckstreet
Well-Known Member
West Virginia
#15
Hi Geoff,
Interesting kit. Is there a photo of what it will look like when finished? The frame construction looks to be historically correct which I really like but that does make the build a little more difficult. Good job on the frames construction so far. I look forward to seeing the kit evolve into a finished model.
Take care,
Bob
A
Aussie048
Guest
#16
Bob
Thanks for visiting my build log. I have posted some photos of what Triton should look like at the start of the build log.
I have been admiring your work on SOS an look forward to seeing many more of your builds of exceptional quality.
Cheers
Geoff
lauckstreet
Well-Known Member
West Virginia
#17
Aussie048 post_id=22271 time=1504993404 user_id=3981 said:
Bob
Cheers
Geoff
My bad Geoff. Don't know how I missed those photos. Senior moment perhaps.
I'll post some photos of my Fubbs model soon. I have to reduce the size as most are much too large to upload to the forum
Bob
A
Aussie048
Guest
#18
Hi Bob
No, you did not miss them I only included them this morning.
It looks like it will make a stunning model. Just hope I can produce to a standard near of what is in the photos.
Cheers
Geoff
Mike41
Well-Known Member
#19
Hi Geoff,
I like the way the frames are assembled. Could you post a photo of the end view of the frames in the box?
Thanks, Mike
A
Aussie048
Guest
#20
Hi Mike
I am only using the box as storage for the frames at the moment to keep them in order.
The fitted the keel in the box yet. The box is that tight a fit I have not glued it at all except for a bottom sheet
Cheers
