Update on display
I like your display case a lot. Practical, efficient, uses minimum of glass or Plexiglas. Glass panels are small so not expensive. Can you share design of how glass panels are secured?
Hi there the best way to explain this issue is the acrylic sheets are lifted up into the top runner letting the sheet then slip across the lower retainer strip of wood and then drop down into a groove behind the wood. Give me a text if you need a dwg and a few days to reply
