USS BONHOMME RICHARD - POF - Cross Section in Cherry - 1:48
I have the kit with all upgrades.
I started with frames. Eight finished, one to go.It is going nice straight forward work only with minor adjustments.
I'm thinking to replace the splited keel parts with new one. But I dont have chery wood.
Uwek
Administrator
Administrator
Vienna, Austria
Very good progress on the frames. Looking good.
the sandwich- keel..... I was also think about to change this part, but decided to give it a try, and after some correction it was fitting very well.
If you do not have Cherry or pear for a replacement - I would not use any other timber for this - but you can work a longer period without the keel.
First of have to fix the frames with the keelson and start the inner planking etc.
So a decision reffering the keel has still some time (weeks to go.....)
Sanding from inside is finished. From outside it need still small touch, will be finished later.
Some planks are installed. Step for main mast is temporary in place.
Next step is measuring the deck positions.
Uwek
Administrator
Administrator
Vienna, Austria
It is looking very good
One question:
how comes the two tone color of the boards of the pump room?
Did you use a different timber than from the kit?
