This is looking very good - Bravo!Added the grating barrier - I think it gives the model an extra level of complexity.
Thanks. I will attempt the coil, but I found a description that in action the “loose ends” were just that - loose. I always think that these things are too large for the scale. I think the rope is fine. The blocks are too big.This is really looking good
The loose ends should be coiled - but check the thickness of your rope - it is looking slightly too thin
Thanks. I will attempt the coil, but I found a description that in action the “loose ends” were just that - loose. I always think that these things are too large for the scale. I think the rope is fine. The blocks are too big. View attachment 181253This is really looking good
Thanks, John.G'day Oldpaperone, a very nice build, its interesting to see all the different ways members build their models, looking forward to seeing more,
best regards john.
The length of these tools were defined by the gun where they have to be used.Does anyone have a scale drawing (1:48), that the could share, of the gun tools like this?View attachment 185459
Thanks for the info. Would the Americans use the French style?and also some more info.
These tools looked slightly different between the navies
Der Föderationsrat sprach über die Diskussion über das Tragen von Dolchen durch pensionierte Marineoffiziere
Die Suche nach Möglichkeiten zur Lösung des Problems, pensionierten Offizieren der russischen Marine das Recht zu gewähren, Dolche zu tragen, geht weiter. Erinnern Sie sich daran, dass Rentner vor einem solchen Recht benachteiligt wurden, was nicht nur bei den pensionierten Beamten selbst...de.topwar.ru
