• Beginning at 5:00AM PST (13:00 UTC) on Friday February 14th, all services in the Los Angeles, California, USA Data Center will be offline to perform a Data Center Migration. Due to the nature of this migration, we anticipate up to 24 hours of downtime to safely complete this work. Please be patient during this time and thank you for being a valuable member of our community.
USS Enterprise CV-6 1/200 Trumpeter
Lithuania
Hello all,
Hm, it has been a while, I mainly do aviation, but I had this model for about two or more years in my stash, and I decided somehow that it is time...
This will be my first carrier, first WW2 and first this large ship, the only ones I''ve done were Queen Mary 2 and cargo ship from revell... Other than that I've done 2 wooden ships... So I wish myself luck. Now my goal is to be done with in within a year... Quite optimistic I know, but we will see...
What are the plans for it? I would love to put some LED like I did on the Queen Mary 2, also I want to populate the ship with planes... Dunno if I will print them on buy them, that is to be determined...
Now what I got for it:
MK1 design detail up set with the wooden deck. The amount of PE makes me cry a bit, but somehow I hope I will manage...
A book about the ship from Legends of warfare by David Doyle.
and well, that is it for now...
1/24 car for scale...
Also trumpeter being trumpeter, the main ship part is not for CV-6 I found that a bit funny...
No the actual work will start soon, just have to somehow find some space for it because this thing... its HUGE.
Any tips tricks are very appreciated, if I make a mistake, please tell me how I can correct it or avoid in future :)
good luck with your build! looking forward to following it, often toyed of buying one of trumpey 1/200 carriers?
I bought it because I like the F4U corsair, and it did some test runs on the CV-6, and the kit was a good deal. Don't like trumpeter much, but they have the most options...
what time period of the war are you going to do the model?
CV-5 USS Yorktown Booklet of General Plans (1940) https://archive.org/details/cv5bogp1940
The first part, before it got painted in "camo" Not sure as how accurately I will do it, but I am sure that I wont do camo (I don't like the look of it)
Now the tump hull is... well... needs work... I want to add the lines (or actual plates) that were visible on the ship because trumpeter hull is completely smooth... Not sure atm how to do it, scribe it or add styrene plates or anything else that be easier, so that is on hold a bit. I started to sand the hull windows down, since trumpeter managed to make some of them oval and I will be adding PE on them. Also general mold line sanding is being done.
IMG20250208190007.jpgrn_image_picker_lib_temp_7e965445-e237-44d6-b81c-daa05b8765fb.jpg
how far away in distance is the camera from the real ship in the photograph but remember your model's scale is 1/200?
use paint as anything else would be overscaled in doing the hull plating.
what aircraft & aa guns come with the kit?
are you going to do the armor belt which can be done with sheet plastic?
Hello all,
Good luck with the build. I have one of the Trumpeter 1/200 WW2 carriers on my wish list. :) Looking forward to seeing you progress this famous ship.
View attachment 500223View attachment 500224
Interesting about the panel lines. The Trumpeter 1/350 Enterprise has the lines, but they were really overdone and needed to be sanded back to make them more in scale/realistic. I've found most all of the Trumpeter ship kits need 'work'. :)
You are going to have to do some research. Enterprise was built when electric arc welding was just beginning to be used for shipbuilding. Before this, ship hulls were riveted. This meant that hull plates had to be lapped. There were alternative “in and “out” strakes of plating. Welded construction meant that plating was butt welded; plate edge to plate edge. This allowed “full penetration welds” that were as strong as the adjacent plates. Riveted joints were not. At 1:200 scale, butt weld seams would be invisible. 40# (I” or .02” at scale plating ) lapped riveted seams would be visible, but rivets invisible.
Your photo is confusing as it shows what appears to be prominent lapped seams but no rivets. Note: Major hull strength welds were NEVER lapped as fillet welds are weaker than the adjoining plates and cause stress concentrations. My guess is that these are riveted seams but the photo is not clear enough to show rivets.
Roger
OK Did a little online research. From photos, it appears that get hull was both riveted and welded construction. This is what your photo above shows. Longitudinal hull seams and some if not all plate splices were riveted (lapped). The large bow assembly shown in the photo was butt welded.
Roger
One thing I found helpful was to but a little weight into the hull. It IMHO makes it a little easier to handle. I took some BBs and used Exopxy to attach them to the bottom of the hull.
Yeah, I will probably will use primer to make the visual overlaping, as everything else will probably look out of scale too much.
About the armor belt I am not quite sure. Do you have references with and without?
There is a great youtube series on building this model. Its called Midwest hobby shop.
Yeah I know, also the Norwegian Modelling Bench. Will be a great help for me.
Yeah, as I mentioned, I tend to avoid anything trumpeter, but I like big scale things... And well, trumpeter is basically the only one...
Roger
yeah, as I mentioned, I have a great book about it, and I am sure that it is overlapping and riveted, but as we all discussed, it need to be really subtle. I want it because its just a huge smooth plastic part that well, IMHO needs something to look better. In the photos that I have, the oil caning is almost everywhere, the hull is not smooth at all, but as you guys pointed out considering the scale I will probably wont be able to make it look good or at least a bit natural...
the armor belt is 4" thick so at 1/200 scale it would be .02" thick. download the Yorktown plans i linked above & look at Sheet 3 - Outboard Profile Starboard & Sheet 17 - Outboard Profile Port Side. the belt sits just above the waterline but most of it is below that line from the forward 5" guns to just past the outboard props.
